Beat Sync button does not deactivate
When I use this button, even if I click on it again...this function remains active...I have to deactivate it manually in virtual dj each time...so it's difficult to make mixes...
Reinstalling virtual dj ..and the FLX4 drive and its update nothing to do ....
Thanks for feedback
le bouton Beat Sync de se deactive pas
Quand j utilise ce bouton , meme en cliquant dessus a nouveau ..cette fonction reste active...je dois la deactiver manuellement dans virtual dj a chaque fois...donc difficle de faire des mix..
Reinstallation de virtual dj ..et du drive FLX4 et sa mise a jour rien a faire ....
Merci pour votre aide
Thanks for feedback
Posted Mon 12 Feb 24 @ 12:28 pm
Auto beat lock on in settings?
Posted Mon 12 Feb 24 @ 1:15 pm
The Sync function in VirtualDJ is not a toggle (on/off) mode. Each time you press the SYNC button the 2 Tracks are synchronized in Tempo and Phase.
If you need to rest the Track's BPM you can change the SHIFT+SYNC action (selects next Pitch range by default) to do a Tempo reset by assigning this key to pitch_reset (for smooth resetting) or pitch_zero (for instant reset)
Posted Mon 12 Feb 24 @ 1:42 pm
Thanks ..can you tell me where I can make this settings ?
Posted Fri 16 Feb 24 @ 1:08 pm
