Topic: smart_fader issue when e.g transit from 155bpm song to slow down to 100bpm song
if enable smart_fader on the 100bpm side, instead of speed up to 155bpm to matchup, it slows down to 78.67, when using cross_fader, the music is not slowing down, it is actually speeding up from 155bpm to 200bpm to match next song (100bpm)
when i did a trick by speed up 100bpm song to around 155 using pitch fader, before enable smart_fader. the next song is sync to 155bpm successfully, however when using cross_fader, the song is slowing down from 155bpm to to around 136bpm, not till 100bpm.
this is a bug i believe, need to fix. great feature but not completed yet.
another issue:
Also when smart_fader is enabled, jog_wheel is restricted to match the grid, i am not able to do any fine beat matching by moving the jogwheel, if the grid is off the the beat, it is acted like the smart_cue is enabled, but it is not.
thank you
again, great work!
Posted Tue 11 Apr 23 @ 4:20 am
Are you using the latest update?
Of course, b7482
