Topic: how do i map instant doubles to a button .. i think vdj calls it clone - Page: 1
what do i do to map clone aka instant doubles
Posted Fri 29 Jul 22 @ 1:03 am
 Best Answer (mapping -----> Button "Load")
holding 1000ms ? clone_deck : load
or
holding 1000ms ? clone_from_deck : load
or
doubleclick ? clone_deck : load
or
doubleclick ? clone_from_deck : load
[ selected best answer by locoDog on Mon 17 Oct 22 @ 8:17 am ]
The command is:
clone_deck
Or if you want to work in the opposite direction:
clone_from_deck
thank you so much
or
or
or
 Selected as best answer
thank you guys u have help me update my ns7 mk1
wollerosekauf wrote :
for more inspiration a video (from Klaus Mogensen and a NS7):
https://www.youtube.com/watch?v=JUpZsI4pJ0I
works all fine and a great update for this old Numark.
Try it...
ooo yes thank you :)
im doing some changes to my mapping on my ns7 ... i just though how i can map my back button to clone deck 2 and my fwd button to clone from deck one
been trying to figure this out today . thank you for your time
nm guys someone on discord helped me out :) u all have a nice one
how do I configure it to be like in serato?
@djcrossfade1200, support that cable coming out of the launchpad I have a mk2 and mine ended up it a loose port [very quickly] with having it in the same orientation as you do.
The command is:
clone_deck
clone_from_deck
On most controllers it will already have been mapped to doubleclick on load buttons
You can also set all keyboard shortcuts to be like Serato in the drop down in the keyboard mapping
Actually there is a whole article on how to make VDJ act more like Serato (to help people switching from Serato to VDJ):
https://www.virtualdj.com/wiki/seratosettings.html
klausmogensen
one click - load track
double click - clone deck
I did it this way like Serato:
Frogui wrote :
klausmogensen
Yes, that is the default VDJ mapping on most controllers - at least recent ones
For instance here it is from the Pioneer DDJ-SX3 default mapping
how to keep it playing after clone from other deck ? like rekordbox?
Clone already does that (keeps playing status).
not on the s5, am i missing something? is there specific code?
I used this and its load only, not playing:
Double click (quickly press twice) has the functionality (it's even displayed directly in the vdjscript you copied). This is how it works for pretty much all pioneer controllers, in Serato as well
Sorry, my bad, I should have written more clearly...
I'm using a Traktor S5. I successfully mapped the instant double function (by quickly double clicking), but it only duplicates the track without playback.
What is this the value of this option keepPlayStatusOnLoadSong? Set it to yes if it isn't already that.
74%
