Hail all:
Looking for a PEQ for VDJ.
Looking at the Extensions, I see a lot, no PEQ though, which I need ...
Now, I'm thinking like Tokyo VOS SlicEQ, or !Zotope Neutron 3, is there something that is VDJ compatible, usable WITHIN (since there are a lot external existing ones, but these are for output, NOT effective in recording, since placed after any sound recording program) VDJ?
Thank you.
Ben.
Thank you.
Ben.
Posted Wed 29 Dec 21 @ 3:57 pm
Your best bet search Google for free vst parametric EQ vst plugins
Posted Wed 29 Dec 21 @ 4:03 pm
I have, sir.
But none speak of VDJ compatibility, so it can be used within VDJ.
Hence I cam here, good sir. :)
Also, does not have to be free.
The ones mentioned aren't either, I think? ;)
Posted Wed 29 Dec 21 @ 4:18 pm
VDJ can host VST and VSTi plugins. Of course they don't state that they're "VDJ compatible" - neither do they state they're compatible with Cubase, or compatible with Ableton Live (etc).
It's a given that VSTs should work in a host that supports VSTs. Find one and try it.
Posted Wed 29 Dec 21 @ 4:39 pm
I have for instance APO, TDR Nova and ReaEQ, none do show up though in VDJ?
(EDIT: NOTE, these are within my Reaper implemented, these show up there, not in VDJ though.)
What am I missing, sir?
Posted Wed 29 Dec 21 @ 4:46 pm
Posted Wed 29 Dec 21 @ 5:03 pm
This my inspire you (although it's a few years old):
Remember that the bit (32 vs 64) need to match so that VDJ 64 bit runs with 64 bit VST's and vice versa
Also you probably want to use the master FX slot on the master pane when using an EQ plugin
Posted Wed 29 Dec 21 @ 5:16 pm
Yup, pro-noob confirmed (me, I mean).
However, I open up the Plug-in Window, still none of the installed are shown though?
Is VST3 btw supported?
Installing Eiosis airEQ ... *crosses fingers*
Posted Wed 29 Dec 21 @ 5:26 pm
Unfortunately VDJ doesn't support use of a central default VST location like other software.
To use a VST in VDJ the dll has to be moved to the plugins folder. It's covered in the manual https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/effects/index.html and in the wiki https://www.virtualdj.com/wiki/how%20to%20use%20VST%20effects.html
Regarding VST3 - no, unless there's been an unannounced change. People have been asking for a long time.....
Posted Wed 29 Dec 21 @ 6:03 pm
Sorry, neighbour had a heart attack went to help.
Heading to the hospital now, I think he'll make it.
Now, Eiosis comes with VST, VST2, VST3, so I should be good.
Thank yo, good people. :)
Posted Wed 29 Dec 21 @ 7:35 pm
