Just a quick question. I'm sitting here mixing only on the program using the internal soundcard and have the same songs loaded on both decks. The right deck sounds like it has more EQ on the treble side but everything is set flat. It just sounds richer.
Why is this please ?
Posted Tue 01 Dec 20 @ 6:17 pm
Hello,
can you show us in picture the settings you made in the audio config of vdj
Posted Tue 01 Dec 20 @ 6:57 pm
having trouble sending pic
Posted Tue 01 Dec 20 @ 7:04 pm
I've fixed it. I went into eq settings and the normal eq on deck 1 was turned on although you couldn't see it because my settings are on ez remix.
Thanks. fixed
Thanks. fixed
Posted Tue 01 Dec 20 @ 7:28 pm
