Hello, I am Javier from Argentina, TDJ (Tango DJ). I am a user of Virtual DJ 2021.
I am amazed at the set of EQ tools the software has.
Most of the Tango tracks I play are from the 1930s through the 1950s.
The original sound tracks usually include some noise caused by the vinyl recording needle.
I wonder if it would be possible to have a removal tool for that type of noise, also present
in old recordings other genres as well.
This would be a most valuable feature for these type of tracks fothe 40s and 50s wich
usually need more processing to improve the overall output audio quality.
To my knowledge there is no other DJ software which provides such a feature which would
make Virtual DJ the first in its class to provide such functionality leading the pack as
usual.
Thanks in advance for considering this feature request.
usual.
Posted Tue 22 Sep 20 @ 1:37 am
Hi, I guess such a feature would require off-line track analysis and processing, as done with some professional audio editors.
Perhaps an extension of the stems feature could be interesting.
Posted Wed 23 Sep 20 @ 7:34 pm
Posted Wed 23 Sep 20 @ 8:03 pm
> https://www.izotope.com/en/products/vinyl.html
Find the error... :c)
Posted Wed 23 Sep 20 @ 8:29 pm
Posted Wed 23 Sep 20 @ 8:51 pm
Quote :
He wants to remove the noise, not add it!
There are VSTs that clean up vinyl noise (i.e. Waves X-Crackle), but usually not in real time. They need to look ahead, so there's a processing delay.
Posted Wed 23 Sep 20 @ 9:17 pm
i guess you didn't read the other post but that's ok :-)
Posted Wed 23 Sep 20 @ 11:50 pm
I read all the posts.
It just wasn't immediately obvious that VDJ Monty was highlighting your mistake
He didn't use quotes, and there is actually an error on the linked web page, so at first glance it looked as if he was just posting the same link as you.
Posted Thu 24 Sep 20 @ 8:29 am
Hi sound forge should do the trick https://www.magix.com/gb/music/sound-forge/sound-forge-audio-studio/
Posted Fri 25 Sep 20 @ 10:39 am
