As the title suggests..i am getting highly audible pops in audio when applying the filter echo color fx regardless of the buffers i use...ps there is no apparent cpu spike..is this a bug..or is it that my system is just lame? Lol
Posted Wed 04 Dec 19 @ 8:51 pm
You are probably using an older Build. This should be fixed in current Public 5402 (or Early Access 5454)
Posted Wed 04 Dec 19 @ 8:55 pm
Can it be confirmed that this is fixed?
Posted Mon 16 Dec 19 @ 3:57 am
Why don't you check what build you're on, and if not what DjDad suggests, update and verify.
Posted Mon 16 Dec 19 @ 7:15 am
