Hi.
I'm currently using the following:
1. Pioneer DDJ-SR2
2. Virtual DJ licensed for the SR2
3. A desktop computer's sound card for the output of the SR2, routed via the USB cable to a standard USB input
Virtual DJ allows me to use the soundcard for the SR2 with an amplifier and speakers OR to use the computer's sound card for the master output.
I prefer to use the computer sound card and some good computer speakers with my dual monitor setup to make recorded mixes. I can use the amplifier and speakers but it bugs my housemates.
I can't really tell from checking the other Pioneer controllers that are supported by VirtualDJ on the website whether they also support the use of the computer sound card. The reason I am interested is that I would like to upgrade to a 4 channel controller.
Does anyone know this? I know it's kind of an unusual application.
I know I could probably get a controller without a sound card that would work so if anyone has some recs for Pioneer or non-Pioneer controllers without sound cards, mid to high end, let me know.
You can check one of my crappy mixes at https://www.mixcloud.com/james-zachary2/one-particle/
Thanks.
1. Pioneer DDJ-SR2
Thanks.
Posted Sat 08 Sep 18 @ 7:09 pm
VirtualDJ allows you to direct the master output to any output you like, regardless of which controller you use or which license you have.
Posted Sat 08 Sep 18 @ 7:16 pm
So much more versatile than Serato.
Thanks.
Thanks.
Posted Sun 09 Sep 18 @ 2:18 pm
