Topic: Flickering skin? - Page: 2
There was a driver, that didn't fix it. It was me being stupid using milkdrop that i transferred instead of installed.
Hopefully me being dim can help other people out.
Posted Sat 23 Jun 18 @ 6:13 pm
I'm having the skin flickering issue also. I'm on a mid 2012 MacBook Pro. Are there any solutions yet?
Posted Tue 26 Nov 19 @ 4:54 am
Milkdrop was the issue on ours. Just disengage and make sure you have shader selected. The issue seemed to only be with Milkdrop in the background.
Posted Wed 04 Dec 19 @ 9:18 pm
It is happening occasionally on different skins; but it happens every time I right click.
Posted Thu 05 Dec 19 @ 2:01 am
Has anyone try to tweak the videofps & skinfps? From my past experience, I have encountered this & solved.
Posted Thu 05 Dec 19 @ 9:10 am
Was there ever an update or solution for this issue?
Posted Tue 10 Dec 19 @ 1:44 pm
Has anyone found a solution to this yet? My screen still flickers when I right click anywhere on any skin. Thanks in advance.
Posted Thu 30 Jan 20 @ 1:36 pm
AdionPRO InfinityCTOMember since 2006
Did you try turning experimentalSkinEngine to No, or skinFps to 60?
Posted Thu 30 Jan 20 @ 1:54 pm
Thanks. If I set experimentalSkinEngine to either "Yes" or "No" the screen flickering stops. It only seems o be doing when set to "Auto"
Thanks again
Posted Sat 01 Feb 20 @ 3:53 pm
