Please help me with this very long script..
it's designed for ddj controllers with the fx assign buttons top of each deck.
with the skin and the script, we will have samplers with full deck control.
Deck 3 fx_assign1 play_stutter on deck 5
Deck 3 fx_assign2 play_stutter on deck 6
Shift + Deck 3 fx_assign1 play_stutter on deck 13
Shift + Deck 3 fx_assign2 play_stutter on deck 14
Deck 1 fx_assign1 play_stutter on deck 7
Deck 1 fx_assign2 play_stutter on deck 8
Shift + Deck 1 fx_assign1 play_stutter on deck 15
Shift + Deck 1 fx_assign2 play_stutter on deck 16
Deck 2 fx_assign1 play_stutter on deck 9
Deck 2 fx_assign2 play_stutter on deck 10
Shift + Deck 2 fx_assign1 play_stutter on deck 17
Shift + Deck 2 fx_assign2 play_stutter on deck 18
Deck 4 fx_assign1 play_stutter on deck 11
Deck 4 fx_assign2 play_stutter on deck 12
Shift + Deck 4 fx_assign1 play_stutter on deck 19
Shift + Deck 4 fx_assign2 play_stutter on deck 20
thanks in advanced
thanks in advanced
Posted Sun 25 Jun 17 @ 3:25 am
you might want to message this guy he was working on a similar project. maybe he can help https://www.virtualdj.com/forums/214143/VirtualDJ_Skins/Remix_decks.html
Posted Sun 25 Jun 17 @ 12:07 pm
well all the actual work was done by JMF and Locodog. But I still have the files. They have moved on to other projects but it did almost get there.
Posted Sun 25 Jun 17 @ 1:27 pm
Posted Sun 25 Jun 17 @ 1:30 pm
