The tractor pro 2 has a much better sound and I believe this is the reason that all clubs.
Please also improved the sound is not bad but the tractor rpo 2 is perfect.
Posted Fri 13 Nov 15 @ 9:19 am
Can you make a recording of playing the same song in both and explain what you think sounds better in traktor?
Posted Fri 13 Nov 15 @ 9:23 am
This I have explained to the greek forum and I and some others do not need a special effort to understand someone that sound in tractor pro 2 is even at high volume Relaxation lucidly FREQUENCY while in virtoaldj that I consider much higher than the tractors to all the rest predominate midrange strongly crushed TREBLE in many songs and a tiring effect on a lot of tension.
Please correct this I believe that the engine sound of tractor pro 2 is far superior.
I write through the translator of google and I do not know if those carried made clear.
Posted Fri 13 Nov 15 @ 12:07 pm
VirtualDJ's frequency response is pretty much as flat as can be.
Any chance the gain is set too high on some tracks?
Posted Fri 13 Nov 15 @ 2:49 pm
@Adion I think atomix should consider -3db as a default zerodb setting I'm sure it would help with these type of complaints.... Crushed highs I think is the give away of badly set gains by the user.
Posted Fri 13 Nov 15 @ 3:56 pm
I would be happy if I had to virtual dj the sound of traktor pro and I believe that the virtual dj would enter all club.
Thanks.
Thanks.
Posted Fri 13 Nov 15 @ 9:00 pm
I agree. A good lot of songs go in to the limiter when gain is just past 12 O clock and that is too tight.
Posted Tue 17 Nov 15 @ 10:11 am
Hi,
I just made the comparison today. I was first surprised that Foobar2000 output a better sound than VDJ.
To sum up : I agree with the original poster, Traktor 2 Pro has a far better sound than VDJ8.
In Traktor, the sound is more dynamic, more details in medium-highs are listenable, bass are more sharp, there is a better stereo image, sound is less tiring, ...
Posted Sat 27 Feb 16 @ 7:15 pm
What equipment are you listening on, to be able to hear all these differences?
Posted Sat 27 Feb 16 @ 7:20 pm
Hi,
My own PA system which is quite well equiped : 2 way active system (15'' + TPL150H), bi-amped and filtered with a BSS366 processor.
In all case, sound is outputted through SPDIF, passes through SRC2496 then feeds the BSS (so it's a digital link from the computer to the BSS).
Posted Sat 27 Feb 16 @ 11:06 pm
And not to forget : I use ASIO driver
Posted Sun 28 Feb 16 @ 12:37 pm
if the sound seems tiring you are most likely hitting the limiter hard squashing the sound ... lower your gains and or adjust zerodb to -3 or -6
Posted Sun 28 Feb 16 @ 2:54 pm
i hit edit and makes a new post with a quote ? sry for all the posts
Posted Sun 28 Feb 16 @ 2:55 pm
Adions request above still stands. Please provide the requested recordings.
Posted Sun 28 Feb 16 @ 4:43 pm
Hi,
zeroDB is already set to -6dB, gains are correctly set, level meters show there is enough headroom.
Since I use VDJ8, limiter has never been triggered...
Posted Sun 28 Feb 16 @ 5:41 pm
BTW : it has been tested with no EQ, at normal speed, ...
Posted Sun 28 Feb 16 @ 5:45 pm
Posted Sun 28 Feb 16 @ 9:23 pm
Hi SBDJ,
I see the request from Adions. Hoewever with the trial version of Traktor 2 you can't currently record the output :/ (and after 30 minutes you have to close/reopen)
But maybe, in a first approach, you can do a listening comparison ?
Posted Mon 29 Feb 16 @ 9:50 am
audacity is free you can use it to record traktor -> https://sourceforge.net/projects/audacity/
only way they can hear what you do is if you make the recording.
you can bet they have already done comparisons themselves many times over and not just to traktor.
Posted Mon 29 Feb 16 @ 10:18 am
Well record the out via audacity or something,
I'll bet that traktor colours the eq,
Posted Mon 29 Feb 16 @ 10:23 am
