after the 2 recent builds my iphone remote is not showing up in the remote tab. enable devices is selected. any thoughts? Thanks
Posted Tue 05 May 15 @ 2:38 pm
I just tried with my iPad. It did not find the device. I removed the device and then enabled it again. Now it works.
Posted Tue 05 May 15 @ 3:31 pm
With mine it doesn't show the iPhone as a device like it did before. ???
Posted Tue 05 May 15 @ 4:12 pm
Have you verified they are on the same network and that the firewall permissions are still okay?
Are you using version 8 or 7?
Posted Tue 05 May 15 @ 4:40 pm
problem solved had to use hardwire...bluetooth wouldn't respond. thanks for your help. cheers
Posted Tue 05 May 15 @ 4:48 pm
Glad it worked out.
Posted Tue 05 May 15 @ 5:00 pm
