Topic: FIle Drag & Drop Issues w/ Virtual DJ 8 - Page: 2
danny_kosa5 wrote :
My problem was solved since I disabled "open as Admin"-mode.
Solved the same way, Thanks!
When I drag and drop a song on deck A while deck B is playing. Deck B stop playing immediately. What I notice it the PLF button automatically switch to the deck which I am dragging the song to and the opposite deck stop playing. Do I need to change some sort of setting? Can someone shed some light on the problem. PS I am new to vitural DJ8.
Does it actually stop playing or sound is cut off but the decks shows as its playing on the skin (Vu meters alive, jog spinning) ?
If its still showing playing but no sound, then probably you have routed the Headphones channel incorrectly.
What exactly do you have in Audio Setup ? (details or screenshot please)
How did you disable 'open in Admin mode', as i have the same issue not being able to drag and drop
You are Freaking Amazing ! I had Video issues and had to reset and turned Admin on. Been trying like Hell to Drag and Drop Visuals into sampler ( No Go ) searched for help and finally found your beautiful answer.
Brother thanks so much. DJ/VJ Mixmaster Jazzy Jay ®™ (@mixmasterjazzyjaylive)
