HELLO
i have a pioneer ddj wego and virtual dj pro full 7.4.
first time i use it - ddj wego and virtual dj le... it run good
with the 20 days trial - with virtual dj pro... run good too
now THE MASTER OUT DOESNT WORK i have updated the virtual dj le to pro full 7.4
Posted Thu 11 Apr 13 @ 2:29 pm
Which Sound Settings did you use?
Config/Sound Setup
DR Phillip :)
Config/Sound Setup
DR Phillip :)
Posted Thu 11 Apr 13 @ 3:06 pm
The same as using virtual dj le
Outputs [HEADPHONES] -- 1&2 MASTER / 3&4 HEADPHONES
Soundcard [ASIO DRIVER] -- DDJ WEGO
With Virtual dj pro full 7.4 THE MASTER OUT DOESN´T WORK
Posted Thu 11 Apr 13 @ 5:14 pm
oh man wish I could help as i love my wego and do not have any issues with it however I am still on 7.2.
Posted Thu 11 Apr 13 @ 7:24 pm
there is a bug in the program...
the master out doesnt work until you down and up the volume
sorry my english not very good
Posted Fri 12 Apr 13 @ 10:20 am
How do I set up my VDJ Pro to control my WEGO like it was meant to work, I can get it to do everything but cue up a track in my headphones without it coming through the main outs. plz help cuz I was told to upgrade to pro from the le and everything would work, I cannot get this to work. plz help
Posted Mon 13 Jan 14 @ 1:49 pm
you have to alter your audio setup, go settings > sound setup > select advanced from the drop down menu.
here you can select a route for your master and a seperate one for your wego, set your master first, and then when you set your headphones you just check each pair of chanels from the list beside the card youve chose.
if your running both master and headphones from your wego your settings will be something like
master - wego - channel 1&2
headphone - wego - channel 4&5 or 5&6
hope this helps, john.
Posted Mon 13 Jan 14 @ 2:13 pm
http://www.virtualdj.com/wiki/DDJ-WeGO.html
Mod Edit. Please post www links only. Do not post links from the French website (//fr.) in the General Forums. Thank you
Posted Mon 13 Jan 14 @ 3:42 pm
Upgrade to Pro Full would not be necessary, unless you needed to preview the tracks from the WeGo and have the Main Output from your computer's speakers.(even though a workaround for this case exists as well)
In that case you will need to choose the Advanced Config from CONFIG->Sound Setup->Outputs, click the new button, and create a setup like this..
Master .. Your computer's built-in sound card .. Outs 1,2
Headphones ... Pioneer DDJ-WeGO ASIO ... Outs 3,4
For Main and Headphones Output through the WeGO, follow the Setup as per the wiki (link from the post above).
Posted Mon 13 Jan 14 @ 4:04 pm
Did you turn the master volume knob on the wego all the way up?
Posted Mon 13 Jan 14 @ 10:57 pm
