Topic: Homemade Gobos. Anyone using Artweaver (or similar graphics package)?
Hi.
I'm trying to make my own gobos.
I have Artweaver but have NO IDEA how to use it.
Please help if you can.
Posted Thu 07 Mar 13 @ 1:22 pm
Let me explain further.
I have a Chauvet Gobo Zoom LED 2.0
I can create custom gobos for it using transparency paper. I would really like to start doing this but I do not really know how to use the software.
There is no dedicated software. Photoshop or any other like software will do. I have Artweaver software which is very similar to photoshop. I also downloaded Paint.NET but I have not figured out how to make something 28.6mm. I only have inches and pixels in Paint.NET so for now, I am using Artweaver.
The rotating gobo size is 28.6 mm outside, 26 mm image.
I would like to make gobos with pictures that I have and create text gobos as well once I learn how.
The 1st problem I am running across is unlocking the background image. The 2nd problem I am running across is rasterizing the layer. I may get past the 2nd if I could get past the 1st problem. I don't KNOW if that's right but i'm thinking it may be.
At this point, that is the help I am looking for. Once I get past these issues, I should be good but I won't know until I resolve my first 2 issues.
Anyone that knows about this stuff..... PLEASE help.
I REALLY could use some help here.
C'mon...
Somebody help me out!
PMd you my email... send me the image i will try...
I get custom cut gobos made by a company here that does lazer cutting.. the other ones wear out fast..
