I want to buy the djx750 and connect it with the MK4 controller to Virtual DJ. ¿Can it be?¿How?
Posted Sat 25 Aug 12 @ 12:41 pm
That shoule be possible, yes. The MK4 does have a built-in audio inferface so shouldnt be any problem.
Connect them with RCA cables (When buying a mixer it usually comes with a few rca cables) like this:
djx750 LineIn ----> RMX Output
The rest is done in VDJ settings:
* External Mixer
* MK4 AudioInterface
* External Mixer
Posted Sat 25 Aug 12 @ 1:19 pm
ok, thanks! And if i want to use the other two canals of the mixer djx750, it's to say connect the channel 3 and 4 to the decks 3 and 4 of virtual dj, can it be possible connecting a rca from the sound of the computer to the channels 3 and 4 of the djx750?
Posted Sat 25 Aug 12 @ 1:25 pm
Well the MK4 does only support 2 outputs, as far as I know you have to get an other AudioInterface because you cant use the djx750 for midi
Posted Sat 25 Aug 12 @ 2:41 pm
Ok, thanks, thats all. ;)
Posted Sat 25 Aug 12 @ 2:53 pm
Finally i'm going ti buy the djx900 USb because is MIDI ;D
Posted Sat 25 Aug 12 @ 7:20 pm
It's not midi... the DDM4000 is and it's a much better mixer but you will still need to upgrade to VDJ Pro to unlock the soundcard routing options or the ability to use extra midi controllers.
Posted Sat 25 Aug 12 @ 7:30 pm
