I did, once.
Posted Fri 24 Aug 12 @ 7:43 pm
I play alot of Genres and i would find it very hard to prepare my sets on a Phone. When i practice at home, I have to play two songs at the same time repeatedly just to pick the right time when i should start playing a song. I want to make sure they sound right when i am mixing live on front of a crowd.
Posted Sat 25 Aug 12 @ 12:12 am
Forget the Pioneer blurb and read was Chris has said... it's an alternative to the MC-6000/3000 VMS2/4, etc when combined with VDJ with 24bit audio and HID. It's user preference if you want to use all the RekordBox and wireless Gizmos...
That said, the price is about 150GBP higher than the MC-6000 for a pioneer controller. Is it really that outrageous?
Haven't read the specs yet, but the one thing that lets the Denon down is the 2 channel audio which means you need an external standard for timecode. Does this controller overcome that limitation?
Cheers,
Roy
Cheers,
Roy
Posted Sat 25 Aug 12 @ 4:12 am
Mine was delivered at the weekend.
Definitely not toy quality. Feels more solid than most other controllers, more cdj quality. The jogwheels are better than CDJs imho
You wouldn't prepare your playlist on your phone, but use Rekordbox on your computer and load to a usb stick or external hd.
Then you can either browse through your playlists, genres, artists, etf on the aero by turning a knob, select a first letter to focus down, and load. If you want to use a phone, you can use it to search for a track on the usb stick or ext hd and then tap the app and it loads immediately.
If you don't want to do it that way, that's fine. If you have a computer with you use rekordbox on it and load from there through wireless. Its instantaneous, so you don't have to plug in the usb. You can use it with usb connection to computer if you want.
Haven't tried it with VDJ yet but am planning to do that soon and will report back here when I have done.
The sync and auto play features actually work, but a bit like vdj, if you don't want to do that, just use the pitch control as usual.
Only drawback I have found is no hot cues, but these will probably follow inb the next firmware release.
Posted Tue 28 Aug 12 @ 7:37 am
The jog wheels are better than on the CDJ2000??? and may I add !!!
Posted Tue 28 Aug 12 @ 11:52 am
The jog is like the NS6. Its alittle loose and feels great when you have your hands on it.
Posted Tue 28 Aug 12 @ 2:25 pm
Yeah, I have never been quite happy with the cdj 2000 jog wheels compared to the cdj 1000 Mk* There have been a number of people thinking the same as me who posted on the Pioneer forums.
Am hoping that I can use with VDJ soon.
Posted Wed 29 Aug 12 @ 5:05 am
have found somebody mapper for xdj-aero?
Posted Mon 10 Sep 12 @ 2:41 am
XDJ-Aero will be natively supported in next update (ver 7.1)
Posted Mon 10 Sep 12 @ 8:35 am
We are still working out some minor issues with Pioneer.
If we resolve them before the next release, then we will make them available for download.
Posted Mon 10 Sep 12 @ 8:23 pm
When is next release? Most needed!
Posted Mon 24 Sep 12 @ 11:09 am
When will be the updated software for XDJ available? I have a console XDJ for which isn“t maping in these days and I would hate to turn to another software.
Posted Mon 24 Sep 12 @ 3:05 pm
Dude look up 2 post from yours and you can clearly read that some things are still being worked out with pioneer....... threatening to turn to another software really doesn't bother anyone. So if you can't wait till it's done, peace but like most you'll return when it's ready.....
Posted Mon 24 Sep 12 @ 8:55 pm
i love virtual. i hate to buy another softer. and more than that i buy a new console. whats really wrong i buy from the best brand on market: pioneer and virtual(the software that i love(after mac os)) don't do anything. no update from one ear. :(
Posted Wed 26 Sep 12 @ 9:27 pm
As it was stated above ...
There are still some issues being worked on with Pioneer.
The XDJ-AERO is first a stand-alone media system. It does have the ability to work with MIDI and HID capable software like VirtualDJ.
Once we are cleared by Pioneer to publicly release the supporting files then we will make them available and post the notice to the forums.
Posted Thu 27 Sep 12 @ 7:35 am
tkx. i hope s gonna be up soon!
Posted Fri 28 Sep 12 @ 7:40 pm
still nothing?
Posted Fri 12 Oct 12 @ 1:33 am
Mapping? Thank you for your answer.
Posted Wed 17 Oct 12 @ 4:00 pm
The Aero is supported in VDJ 7.2
Posted Thu 18 Oct 12 @ 8:07 am
the price is too high and the feel of it is very chep
Posted Thu 18 Oct 12 @ 8:21 am
