Forum: Old versions
Topic: Virtual DJ Pro and Presonus Audiobox USB 2x2 interface problem/configuration
Hi,
Does anyone know how to get the PFL function in Virtual DJ Pro to work when using a Presonus Audiobox USB 2x2 interface?
Thx.
Posted Tue 17 Apr 12 @ 9:21 am
The Audiobox 2x2 is a 2-channel (= 1 stereo channel) out soundcard. With just htis card it is not possible to use headphones, unless you use a splitter (Left and right channel are split to Master Out and headphones.) The headphones-oputput is not a separate output.
Option 2 is to use the internal soundcard from your computer as output for the headphones.
I returned it and got a Presonus Firestudio mobile as Presonus says the headphones can be configured as a separate output but they are not familiar with Virtual DJ. How can I set this up with the Firestudio? Thx.
