Forum: Old versions
Topic: numark ns6 (left deck only) rewind/ reverse scratch muted audio issue. please help!
hey guys i tried changing the default sctratch latency value whit the registry tool but as soon i did that my left deck its not making any sound when i rewind the platter like in reverse, the right deck its fine, its just like if the reverse (rewind) audio its muted on the left deck, i see the movement on the indicator on the platter of the ns6 and in virtual dj but no audio is comming out the mixer only on regular play back and scratching forward. note i didnt change anything else exept the default scratch latency whit the registry tool to 1024. the bad thing is that i dont remember the default setting to bring it back the way it use to be, i updated gamebooster 3 at the same time i changed the settings on the registry tool before testing vdj first do you think that had something to do whit the problem? any help will be apresiated cuz its been a day already like that and its pretty frustating cuz i have a monday-saturday radio mixshow, i allready uninstalled- re-install the numark ns6 drivers and no luck same whit the new updated version of gamebooster 3.3.1
Posted Tue 28 Feb 12 @ 5:43 pm
have u fixed the left deck? mine isnt makin a sound wen it rewinds to
never mind to fix it u have to reset the settings. go to Config then go to info and click on 'reset to factory settings'.
