Topic: Numark 4Trak- is there a virtual dj mapping yet? - Page: 2
How you made so that the 4trak works with virtual DJ ?
There is a full working mapping so if you own a copy of the Professional Full version you can fully use the 4Trak within VDJ.
Greets, Heiko
i down loaded all your mapping. Now how do i install it on VDJ?
Put the 2 mappers files to your Virtual DJ\MAPPERS folder and the 2 definition files in the Virtual DJ\DEVICES folder.
Greets, Heiko
Am used windows vista 32bit with numark 4trak virtual dj pro . Everything is working for me but scratches is very bad is way to fix it.
This is a problem of your Operating System i would think. Most users have problems with Vista.
Just my 2 cents.
Greets, Heiko
numark 4trak works with vdj but as soon as i start to mix from four deck in scratch mode useing jog wheel everything act up i was useing window vista so i upgrade to window 7 thinking that was the problem but still doing it. i aways dj with vdj tri trakor software that come with the 4trak not for me i love vdj it the best software love to get this 4trak working with good (4trak driver2.9.55 am useing
Unfortunately no one will send you the mapper by email.
As for the license because it is registered to another account there is nothing that can be done there. Guess you'll have to be nice to the ex-girlfriend.
More then likely I am just gonna be losing money again. Nice won't cut it with this one. lol. Bi-Polar+Vindictive=Mayhem.
Well since my options are limited I may as well ask...Can I map my 4trak manually to Vdj?
Not with LE - requires a Pro license in order to change these settings.
i still have pro on my pc. so if its pro i can?
ah yes, in that case you could.
Technically you shouldn't have Pro as you don't have the license for it.
But as you have it, then yes it can be mapped.
HI GUYS JUST DOWNLOADED VDJ8 LAST NIGHT I HAVE A NUMARK 4TRAK BUT I CANT GET A CLEAN SOUND AND FULL MIXER IS NOT WORK I HAVE A GIG TOMOROW AND I SWITCH FROM TRAKTOR PLEASE HELP ME TO HOW MAPPING A FULL VDJ8 TO NUMARK 4TRAK THANKS
i guys
sAm useing numark 4trak with virtual DJ 8 everything works well except the C and D layer button doesn't lights up on the controller work fine with virtual DJ 7 on with tractor pro. is anyone have this problem on know how to fit the mapping
