Forum: Old versions
Topic: Help! Traktor Audio 6 w/Timecode Vinyl (Low TC Signal)
Okay.
At whit's end here. :/
Spend $275 on this big high fillutin DJ soundcard and whatya know, it's not working. Anyways, this is my setup.
I have two (Shitty) Gemini TT02's w/Stanton 505 V3's and CV02 a Scratch Lives
Traktor Audio 6
No external mixer, wanted to keep using DJ Control Steel as midi controller and not use external mixer.
Using Advanced Config ("Mono Channels" Not ticked):
Master - Traktor 6 ASIO - Output 1&2
Headphones - Traktor 6 ASIO - Output 3&4
Timecode 1 - Traktor 6 ASIO - Input 3&4
Timecode 2 - Traktor 6 ASIO - Input 5&6
Timecode Config:
Serato Vinyl CV02-A
Debug Settings:
LP Filter, ticked
Disable Pitch, ticked
I am running 3.0.0 Drivers for the Traktor Audio 6.
Have tried on vdj pro 6 and 7, same outcome.
I am getting an extremely low timecode signal, usually about %3-%10...I see two round green circles but again, very bouncy quality :/...also when I load a deck with an mp3 and press play on the turn table the pitch with gradually increase and cause the BPM readout to eventually read like 1500 BPM.
I don't want to use Traktor because it's crap. Not only that, NI forgot to mention on their packaging that you cannot use Timecodes in the Traktor 2 LE which comes with the card, even though the packaging clearly says, "To hook up your turntable!"...yeah, bull****. And I really like using my Control Steel as a mixer, it feels awesome.
Please help
Posted Thu 09 Jun 11 @ 11:26 am
dude does the steel not have a built in sound card ...
if it does you can directly plug the decks into the hercules steel and set up the codec's using virtual dj.
mess about with the mode settings .. and debug and change the 45 rpm ... cant tell ya anymore than that till i get my new decks in the post .. sorry dude
