Forum: Old versions
Topic: problem with vdj, songs breaking, bpms not showing, mp3 not playing
hello,
i have some major problems with the new vdj pro:
-the songs are loading very slow. some of them are not showing the bpms, only when u click on the track, it is showing on the clicked area.
-while tracks are running there are some breaks, which are very very short but also annoying
-and mp3 files are not playing! some of them showing "error"
what to do?? pls help
Posted Mon 27 Dec 10 @ 11:02 am
Me too same problem with Mp3 error and I load a song I see the name but I hear another song instead...running on VDJ Pro 7 with Dn-Hc-6000 .
I have Another kit pcdjVj with denon Hc-4500 And no problems at all .
Help please.
This is an old thread from the end of last year, however in answer to your question and the original questions:
Assuming that you have a computer that meets or exceeds the recommended requirements shown on the page http://www.virtualdj.com/products/virtualdj/index.html then make sure that you have the latest v7.0.2 Pro installed http://www.virtualdj.com/download/updates.html and under CONFIG -> Performances you have the Fast Resampling option selected for 48Hz conversion.
The breaks in songs may be due to performance issues with your computer and/or incorrect configuration in VirtualDJ. Please see http://www.virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html for a list of common causes of performance issues and their solutions.
If you get 'Error' when trying to load a song, then it means that the song in your database is no-longer valid. This is usually caused by either moving, renaming or deleting the song outside of VirtualDJ, so the entry in its database no-longer points to a valid file.
To fix this problem, use VirtualDJ to browse to the drive(s)/folder(s) where your music is located, right-click on them and choose Add to search DB.
Once you have done this, go to CONFIG -> Browser, choose each drive in turn where you have music stored and click on CHECK.
If any problems are found, click on FIX.
You can remove the old redundant database entries by clicking on CLEAN.
NOTE: If you have not already done so, you should update your DN-MC6000's firmware and drivers to the latest version from http:/www.denondj.com
