Forum: Old versions
Topic: Using Serato Sl3 as a sound card for VDJ?
Ok i have looked all over this forum and have not found step by step on how to get my sl3 to work with vdj now i have version 2.2.0 and i have downloaded the new drivers but when i turn on vdj and try to select an audio device i only get these choices.....
SL1 driver
MP 4 driver
TTM 57SL driver
None of which work by the way if someone can help me and tell me what im doing wrong.
Posted Mon 29 Nov 10 @ 1:49 pm
Ok i figured how to get the sl3 to show up as one of the sound devices.... What i as doing wrong was intsalling the 64bit drivers and instead i am supposed to install the 32bit drivers but now im getting an asio error saying that the device is not connected or the settings are wrong. please help
Have you updated to the lastest fimrware Serato has released?? Mine works perfect.
Huey
Card Works great with vdj on windows 32 bit systems. But on 64 bit systems vdj does not see the sl3, even tho it has been installed correctly & u can access the rane control panel. I was just looking for any suggestions on how to get this to work wit vdj on win 64. i hit up rane and they said the card and drivers were set up right and any audio program should see it fine..........win 64 is very frustrating!
Yeah i just realized that it does not work on 64bit sytems because VDJ is a 32bit program so when load up the 64bit drivers it will not work i hope someone fixes this or maybe they can put out a 64bit version of VDJ.... We can only Hope...lol
jus use d 32bit asio drivers......i seeing my sl3 with d 32bit
Does anyone know how to install the Windows 7 32 bit ASIO drivers for SL3? When I try to install it automatially recoginizes that I have 64 bit. Then I cannot see the SL3 on the sound setup config screen. Is there an easy way to load the 32 bit ASIO drivers?
Try choosing Sound card: ASIO -> Choose the SL3 in the drop-down list.
If you have a 64-bit computer then you should be installing 64-bit drivers.
I installed the 64 bit drivers but VDJ7 does not recognize the SL-3. I'm having the same issue as the person in the first two posts had.
can someone tell me what is a decent usb soundcard for queing songs etc
^ START A NEW THREAD
