Topic: Will the BBE d82 Sonic Maximizer work with VDJ?
I'd like to know if the BBE d82 Sonic Maximizer software plugin will work with VDJ. I know the 482i and 882i signal processor units will work, but I was curious if this plugin will work so I don't have to carry around extra sound equipment because space is at a premium for me.
Posted Sat 17 Apr 10 @ 1:55 am
do you have a link for it? Id like to see if it would work for me..
Then i might get one for my rack..
Yeah, I'd be interested to know, people who have them seem to love them, so if a plugin could do the same thing that would be brilliant.
I use a BBE 482 Sonic Maximizer, it makes the music clearer. Love it.
If they can make software to do the same thing then I may have to check it out.
It is a VST plugin - Windows® RTAS, VST -- but I have never used it so I can not confirm if it does work. But VirtualDJ does support VST plugins.
I've just downloaded the trial version of the pluggin and it works. You have to copy the 'D82 Sonic Maximizer.dll' file from 'C:\Program Files\Steinberg\VstPlugins\BBE Sound\' folder to 'VirtualDJ\Plugins\SoundEffect\' folder. Than activate the pluggin and play around with the virtual knob and you will hear the difference :)
very useful, thanks.
Bad news :( ...after upgrading to v 6.0.8 vdj don't start unless I delete the bbe d82 plugin. After deleting the plugin vdj starts. If I copy the pluggin back to sound effect folder vdj won't start. I don't know why.
In event viewer is an application error task 100 with this general info:
Faulting application name: virtualdj.exe, version: 6.0.8.0, time stamp: 0x4bcb702a
Faulting module name: KERNELBASE.dll, version: 6.1.7600.16385, time stamp: 0x4a5bdaae
Exception code: 0xe06d7363
Fault offset: 0x00009617
Faulting process id: 0x1208
Faulting application start time: 0x01cadf504bf39e75
Faulting application path: C:\Program Files\VirtualDJ\virtualdj.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
Report Id: 8d65174f-4b43-11df-a3ba-b1c584ff650f
and this detailed info:
virtualdj.exe
6.0.8.0
4bcb702a
KERNELBASE.dll
6.1.7600.16385
4a5bdaae
e06d7363
00009617
1208
01cadf504bf39e75
Put it back in there and reboot the computer, does it work?
No, it's not working. I forgot to write the specs: asus g2p laptop (core2duo t7200 cpu, 2gb ram, ati x1700 dedicated 512ram), windows 7 ultimate.
I can confirm this plugin is working perfectly on my XP sp3 system cue 6.0.7 & VDJ 6.0.8
has anyone got the demo to run on Win 7??
im gettin "User privilages insufficient to start a low level driver"
when i try and click on sonic maximiser in VDJ (6.0.8) (in Effects)
