Topic: Anyone else using Echo Indigo DJX Expresscard Sound Card?
Would you please post your settings in VDJ for this sound card and in the DJX Console?
I have had a few very slight glitches in sound and want to make sure my settings are correct. THese are very slight and only really noticable by myself but I want to get them corrected.
Is anyone else noticing any issues with this card?
Many thanks in advance.
Scott
Posted Sun 28 Mar 10 @ 8:28 am
45 views and no one uses this setup?
Courtesy bump.
Try to increase the latency in the ECHO ASIO audio panel, I use 512 and it's ok.
What do you have your VDJ settings at?
In audio setup I have select Echo ASIO without ultra-latency.
About performance:
