I hope someone can clarify what the heck is going on. 80% of my Karaoke .zip files do not work. They are the same files as the ones that DO work. All the files work in PCDJ without a problem.
Can someone explain what I have to do to get them working? I dont WANT to have to go back to PCDJ for Karaoke after using VDJ for my music & Vids for so long.
Thanks again everyone. VDJ RULZ!
Posted Mon 06 Jul 09 @ 10:56 am
vsnsound wrote :
Which cracked version are you using?... that may help us determine the problem you are having?
After using VDJ for my music & Vids for so long.
Posted Mon 06 Jul 09 @ 10:58 am
Not sure what a cracked is but I have version 5.2. Bought it about 5 months ago.
Mabey I need to download new Codex?? not sure. Please help
Posted Mon 06 Jul 09 @ 11:25 am
Ok then... why don't you try downloading the latest update and see if that takes care of the problem. (You will have to register your software to download 6.0.1.)
Posted Mon 06 Jul 09 @ 12:11 pm
This issue has nothing to do about cracked or registered versions.
Please, read the topic below
http://www.virtualdj.com/forums/111019/General_Discussion/Why_has_the_CD_G_recognition_been_changed_in_6_0_1.html?search=karaoke&page=1
Posted Mon 06 Jul 09 @ 8:33 pm
but the guy (above) is having issues with 5.2 not v6xxx
Did the issue with your zip files happen 5 months ago when you downloaded your v5.2, or has it just started to do what you say?
Posted Tue 07 Jul 09 @ 7:39 am
I would suggest to UNZIP the karaoke songs that dont load properly (when they're zipped)
you could do this just before you need to play the track, as it only takes a few seconds.
to do this...
1. right click the file in the VDJ browser and open in explorer.
2. in explorer, right click and unzip
3. drag the new mp3 file back to vdj
4. it now plays as it should.
Also, i still cant work out why people like to zip their cdg files when 1tb harddrives are now just £50
to do this...
Posted Tue 07 Jul 09 @ 7:46 am
Thanks for ALL the advice.
What I did was found 1 of the karaoke songs that didnt work and unzipped it. Then added it to the search and found it again and it worked fine.
NOW how the heck do I unzip 41,000 files at once? Anyone know how to do this?
Ill start going 1 by 1 but I hope someone can answer my question before my fingers fall off :)
Posted Tue 07 Jul 09 @ 8:28 am
Ok, I found a program called Unzip them all. It is a free download. Just google it. It unzips entire directary. I have tried it unzipping a directary and it works.
Just thought I would let everyone else know thats having the same problem.
Thanks again group.
Thanks again group.
Posted Tue 07 Jul 09 @ 10:34 am
The only against the unzip procedure is rename thousands cdg+mp3 files. Its annoying, specially when some unzipped files dont bring the singer and song names, just a catalog description.
About the issue also happenings on 5.2... thats weird. Maybe theres something out VirtualDJ zip decoder, thats doing it. Even if all my files are already unziped, I expect it could be solved, anyway.
Posted Thu 09 Jul 09 @ 8:20 am
Has anyone considered MP3+G Toolz.Net4? Withe this free program you can unzip or convert
DJ RuDe
DJ RuDe
Posted Thu 09 Jul 09 @ 11:36 am
as far as i knew VDJ diddnt handle .zip files any way?????????? since when did VDJ have a de-compressor built in???? i would say extract the Karaoke files into a folder then they will play without any problems.
not too sure about you guys but that seem to be the most obvious answer to me...
Posted Thu 09 Jul 09 @ 12:35 pm
Blulite
Off course VDJ can handle .zip files.
Example: All skins are orginally installed at .zip folders. If VirtualDJ couldnt decompress it, how could the skins works fine?
Rude
I did, use a unzip tool, but some files don't brings the singer and song name, only the catalog position of the karaoke supllier. Rename these files, is the boring part of the job.
Rude
Posted Tue 14 Jul 09 @ 9:17 pm
DJ RuDe
DJ RuDe
That's what I use - it works fine as long as compression is set to "5 - default" if you plan to zip them back up...I don't run zip files anymore though, due to issues with the karaoke plugin title/artist display.
Posted Tue 14 Jul 09 @ 10:05 pm
hey guy's i'm trying to get a karaoke thing going, need to know the best software i can get i would even like a link to a free download so i can sample it before i buy, i also need to know if my mp3's can work with this software. i have vdj6 please remember i have never done karaoke. help please
Posted Sat 22 Aug 09 @ 7:12 pm
DJRudeDoGG wrote :
Keep Spinnin'!!
DJRudeDoGG wrote :
This is not really part of the majority of the conversation here but it pertains entirely to the thread title and topic...Here is a 4 part YouTube tutorial I did on ripping CDG discs to CD+G files, then converting them to a single zip file for simplicity's sake. The final video in the series briefly explains how to initialize and use your new files with the most recent VDJ releases including 6.0 and 6.0.1 and beyond I'm sure...
Part I
Part II
Part III
Part IV
If you have any questions leave them in the comment section of the corresponding video on my channel.
DJ RuDe Helps DJs!
DJ RuDe
Keep Spinnin'!!
Part I
Part II
Part III
Part IV
DJ RuDe Helps DJs!
DJ RuDe
Keep Spinnin'!!
Keep Spinnin'!!
Posted Sun 23 Aug 09 @ 12:08 am
djrude, i downloaded the latest version of power cdg and it seems the update makes one file. It is in avi or mpg2. i have used the avi and the mpg2. They both look and play fine when i run them in vdjpro6.2 . Just thought i would let you know.
Posted Sun 20 Sep 09 @ 12:47 pm
Most all these CDG karaoke file problems are related to compression of the zip so unzipping and rezipping at a lower rate will solve a great majoity of the problems.
Also a mismatch naming or special characters will cause a problem in CDG & Mp3 files from playing, so clean them up.
Joey.....
Joey.....
Posted Sun 20 Sep 09 @ 3:15 pm
Hi I am a new user of vj and new to the forums, I have a problem when i use the karoke on vj. Once a singer has chosen a song to sing and i put it in the play list, \\there does not seem to be anywhere for the singers name to be put.. can anyone advise me on this problem please.
kimberly from accrington.
Posted Sun 27 Sep 09 @ 9:45 am
