Hi i search into the forum a topic with software limit but i can't find.
When i need to play into a playlist on the beach bar i select hundred of mp3 and each mp3 have different volume and vdj not work very good with autogain.
I want a program with volume limit for master out volume.
If somebody medlle at gain and the gain go out + 24 db my volume at master exit on sound card to not go out and each melody to have different volume.
I need a limit compresor software .
If somebody can help me with a suggestion ....
Posted Mon 19 May 08 @ 3:01 am
The best solution is to get hardware compressor-limiter. I use plugin for Winamp and it's working ok, but I don't know if there is software for Windows.
Posted Mon 19 May 08 @ 3:19 am
Try SRS WOW Wrapper 1.0
Download here http://www.virtualdj.com/addons/view.html?type=sound%20effect
Posted Mon 19 May 08 @ 3:25 am
I don't want a external hardware.
I want a software for master output for working separate and independently .
Auto gain control software ..compesor limiter...
SRS WOW Wrapper 1. work with single channel once.
Posted Mon 19 May 08 @ 3:50 am
You may want to consider normalizing all your tracks.
Take a look at this post:
http://www.virtualdj.com/forums/88896/General_Discussion/Volume___Gain_levels.html?highlight=great%20find%20volume
Posted Mon 19 May 08 @ 8:16 am
I was reading this and other threads regarding the auto gains. Just a thought, if you normalize your music now you have to reset your cue points. Well, I guess it's a fair trade rather than worrying about the levels constantly.
Posted Mon 19 May 08 @ 12:17 pm
I contacted Team about Autogain and they will improve it in near future, stay tuned.
Posted Mon 19 May 08 @ 12:45 pm
Get MP3trim pro to set normalize your tracks. MP3gain is also good (and free), but IMO not as good.
A good VST compressor, which I use myself, would be the MPL-1 PRO from Kjaerhus
Posted Mon 19 May 08 @ 3:21 pm
