Forum: General Discussion - Topic: skin resize problem
Anything about Virtual DJ, Numark Cue, Numark Virtual Vinyl or AtomixMP3, or not about them*
This a general discussion. Please be polite and speak with respect.
(*) The moderators hold the rights to delete undesired posts.
VirtualDJ forums
General Discussion
skin resize problem
Author - Topic: skin resize problem -
pioneerdigi
Professional edition user
Posted Thu 15 May 08 @ 9:03 am
Hi everybody,
I'm trying to resize a skin (1280x1024) to 1024x768. I'm downloaded VDJ Skin Resizer, I followed instructions and I placed the .rar file with the .xml an .bmp file in the Skins folder. The VDJ Skin Resizer shows no error during the resizing procees. But when I open VDJ the skin doesn't appear on the menu. And when I put the resized files in the original .rar file (2 skins in the same .rar) an Error message is displayed.
What do I do?
Thanks
TearEmUp
Moderator
Posted Thu 15 May 08 @ 9:08 am
The Skin re-sizer really only works well if the resizing is of a matching format. Example: It cannot re-size a square skin into a rectangular one. Your best bet might be to try a different skin. What skin are you trying to resize??
pioneerdigi
Posted Thu 15 May 08 @ 9:12 am
Pioneer_CDJ_1280x1024_DJM_Mixer
I downloaded it from the VDJ website.
Caliente123
Posted Thu 15 May 08 @ 8:22 pm
I find it ridiculous that not every skin fills up your screen depending on what skin you use. Rane serato no matter what native resolution you have it on. It fills up the screen completely. This is supposed to be a proffesional software and by not having the screen filled up, it doesnt look proffessional at all. I dont see how a company that has been around longer than serato still have problems with skins, time codes etc and rane serato, a company that's been around for a short time make so much splash and work flawless.
Site map
(C)opyright Atomix Productions 2008
Software
VirtualDJ Pro
VirtualVinyl
Numark CUE
AtomixMP3
VDJ HomeEdition
DJC Edition
eJay DJMixStation
DJ-Box
Features
Screenshots
Trial Version
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Sound Effects
Video Effects
Samples
Languages
Grafx
Tools & Drivers
Forums
Users Network
Wiki
Radio
Atomix Productions
VIP DJs
Disclaimer
Ask a question
View your tickets
Wiki
