Forum: Mix lessons - Topic: Advice on using an External Mixer
Welcome DJs! Share your skills and help other users here!
VirtualDJ forums
Mix lessons
Advice on using...
Author - Topic: Advice on using an External Mixer -
Mkhululy
No license user
Posted Sat 10 May 08 @ 7:44 pm
How to record mixtape using an external mixer, a 2 channel mixer with BPM counter on it? Whenever I play back my mix tape when the fader is on the middle it will mute then start the song I was mixing with. I have 5.1 channel sound card, but I configure it for 4.1 channel.
superstardj
Professional edition user
Posted Wed 04 Jun 08 @ 1:35 am
Im having a problem also with recording mixtapes. Im using Vdj Club.I forget what version. But when I use my external mixer to record a mixtape it sounds all fucked up. The reason for it is because my cross fader on my software is still left in the middle. I wanna know how I get my software crossfader to move with my external mixer crossfader so u wont hear both songs when I'm cueing up a song.
EXAMPLE.
If I hav a song playing on 1 deck and then I cue up another soong on deck 2, you can hear me cueing it up on my recording.
How do I stop that???
TDBennett
Limited edition user
Posted Wed 04 Jun 08 @ 8:32 am
If you guys aren't using a midi mixer that interfaces with the software then you will have to purchase one or not use the external mixer when you want to record. The recording is done from within the software, the software is not aware of the external mixer. Use the crossfader in the software when you are recording your mixtapes.
djsherz
Posted Thu 05 Jun 08 @ 8:04 pm
Or send a feed from your mixer's output (most have a dedicated "rec out") into the line in of your soundcard, and select "line in" in VDJ's recording settings.
Site map
(C)opyright Atomix Productions 2008
Software
VirtualDJ Pro
VirtualVinyl
Numark CUE
AtomixMP3
VDJ HomeEdition
DJC Edition
eJay DJMixStation
DJ-Box
Features
Screenshots
Trial Version
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Sound Effects
Video Effects
Samples
Languages
Grafx
Tools & Drivers
Forums
Users Network
Wiki
Radio
Atomix Productions
VIP DJs
Disclaimer
Ask a question
View your tickets
Wiki
