Forum: General Discussion - Sujet: VISTA 64 bit does NOT work with my scratch LIVE soundcard - Page: 1 |
| Auteur |
- Sujet: VISTA 64 bit does NOT work with my scratch LIVE soundcard - |
Hakeem2k3
| Posté Sat 10 May 08 @ 17:47:35 |
I use Virtual DJ w/ serato soundcard. Just purchased a new laptop and it has vista ultimate 64bit. Does not recognize the driver for installation. any recommendations. Should i take my computer back and get 32 bit vista? |
discobrian24
| Posté Sat 10 May 08 @ 17:50:11 |
I would take it back. You arent gonna find very many soundcards that have drivers for 64 bit. |
DJ-ALF
| Posté Sun 11 May 08 @ 02:27:22 |
I agree, I think it is early for any 64bit OS. |
cstoll
| Posté Sun 11 May 08 @ 03:21:16 |
| Hakeem2k3 wrote : | | I use Virtual DJ w/ serato soundcard. Just purchased a new laptop and it has vista ultimate 64bit. Does not recognize the driver for installation. any recommendations. Should i take my computer back and get 32 bit vista? |
This is a Serato box - contact Serato about support for their box. If they don't have 64-bit drivers then you need to go to a 32-bit solution. |
RicardoM
| Posté Sun 11 May 08 @ 05:04:31 |
Well I use XP Pro 64 bit edition and have non issues with VDJ and with the Denon's HC-4500 sound card. Pure stability, for me is the most stable windows version. |
DJ-ALF
| Posté Sun 11 May 08 @ 13:02:34 |
I use XP 32bit and it is rock solid also, it's all by tweaking and leaving machine clean just for DJ-ing ;) |
paulheu
| Posté Sun 11 May 08 @ 15:42:36 |
Just assuming you do have the latest (vista) drivers from serato? |
dj t boogie
| Posté Sun 11 May 08 @ 16:19:02 |
i had to downgrade to vista 32bit for this reason !!
its stated on there website somewhere that they have no plans for 64bit drivers.
" Scratch LIVE currently only has a driver for 32-bit Vista and will not work on the 64-bit version.If you have a 64-bit version of Vista installed then you will need to find your installation DVD, insert the DVD, restart Windows, and it should give you the option of installing the 32-bit version.
A word of caution, if you have been using a 64-bit version of Vista and have saved files then you must back-up these files to an external drive or burn to DVD, as re-installing Windows will delete everything. Here is what Microsoft have to say about the differences between 32-bit and 64-bit Microsoft's FAQ on 32-bit & 64-bit Windows."
see here~ http://www.scratchlive.net/articles/scratchlive/?article_id=67 |
Hakeem2k3
| Posté Sun 11 May 08 @ 17:43:39 |
thanks t boogie.....the sl soundcard makes my audio sound more clearer than ever, and both searto tccds and vinyl work flawlessly w/ my vdj. they are more readily available when i need them. i exchanged the laptop for 32 bit. thanks
| - Poster un nouveau Message - |
