Forum: General Discussion - Topic: VISTA 64 bit does NOT work with my scratch LIVE soundcard
Anything about Virtual DJ, Numark Cue, Numark Virtual Vinyl, AtomixMP3, etc... or not about them*
This a general discussion. Please be polite and speak with respect.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
VirtualDJ forums
General Discussion
VISTA 64 bit...
Author - Topic: VISTA 64 bit does NOT work with my scratch LIVE soundcard -
Hakeem2k3
Professional edition user
Posted Sat 10 May 08 @ 11:47 am
I use Virtual DJ w/ serato soundcard. Just purchased a new laptop and it has vista ultimate 64bit. Does not recognize the driver for installation. any recommendations. Should i take my computer back and get 32 bit vista?
discobrian24
Moderator
Posted Sat 10 May 08 @ 11:50 am
I would take it back. You arent gonna find very many soundcards that have drivers for 64 bit.
DJ-ALF
Moderator
Posted Sat 10 May 08 @ 8:27 pm
I agree, I think it is early for any 64bit OS.
cstoll
Atomix Productions
Posted Sat 10 May 08 @ 9:21 pm
This is a Serato box - contact Serato about support for their box. If they don't have 64-bit drivers then you need to go to a 32-bit solution.
RicardoM
Posted Sat 10 May 08 @ 11:04 pm
Well I use XP Pro 64 bit edition and have non issues with VDJ and with the Denon's HC-4500 sound card. Pure stability, for me is the most stable windows version.
DJ-ALF
Moderator
Posted Sun 11 May 08 @ 7:02 am
I use XP 32bit and it is rock solid also, it's all by tweaking and leaving machine clean just for DJ-ing ;)
paulheu
Posted Sun 11 May 08 @ 9:42 am
Just assuming you do have the latest (vista) drivers from serato?
dj t boogie
Posted Sun 11 May 08 @ 10:19 am
i had to downgrade to vista 32bit for this reason !!
its stated on there website somewhere that they have no plans for 64bit drivers.
" Scratch LIVE currently only has a driver for 32-bit Vista and will not work on the 64-bit version.If you have a 64-bit version of Vista installed then you will need to find your installation DVD, insert the DVD, restart Windows, and it should give you the option of installing the 32-bit version.
A word of caution, if you have been using a 64-bit version of Vista and have saved files then you must back-up these files to an external drive or burn to DVD, as re-installing Windows will delete everything. Here is what Microsoft have to say about the differences between 32-bit and 64-bit Microsoft's FAQ on 32-bit & 64-bit Windows."
see here~ http://www.scratchlive.net/articles/scratchlive/?article_id=67
Hakeem2k3
Posted Sun 11 May 08 @ 11:43 am
thanks t boogie.....the sl soundcard makes my audio sound more clearer than ever, and both searto tccds and vinyl work flawlessly w/ my vdj. they are more readily available when i need them. i exchanged the laptop for 32 bit. thanks
Site map
(C)opyright Atomix Productions 2008
Software
VirtualDJ Pro
VirtualVinyl
Numark CUE
AtomixMP3
VDJ HomeEdition
DJC Edition
eJay DJMixStation
DJ-Box
Features
Screenshots
Trial Version
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Sound Effects
Video Effects
Samples
Languages
Grafx
Tools & Drivers
Forums
Users Network
Wiki
Radio
Atomix Productions
VIP DJs
Disclaimer
Ask a question
View your tickets
Wiki
