Forum: General Discussion - Sujet: What does Network Syncronization do? - Page: 1 |
| Auteur |
- Sujet: What does Network Syncronization do? - |
getinthemix
| Posté Fri 07 Mar 08 @ 03:24:27 |
I read the tiny bit in the manual and did search to find out but there is only one post from 2004 on this. What does the function do? Specifically what does it do over a network.
I have a laptop that I use to set cue points and arrange folders and a "Clean" rack mount PC for events that I syncronize my music and cuepoints to. Can this feature help with this? |
cstoll
| Posté Fri 07 Mar 08 @ 04:08:14 |
No. The Network sync is for networking 2 instances of VirtualDJ together between 2 computers for use. |
spacecowboy_uk2001
| Posté Sat 03 May 08 @ 16:32:45 |
Does this need to be via a network via a switch/router? or can u simply plug a ethernet cable between both computers?? |
RicardoM
| Posté Sun 04 May 08 @ 02:24:50 |
Its based on windows lan, Can be used via a Hub/switch/router or simply by a xover ethernet cable. If you go for the xover cable, then be sure to assing IP adresses. |
hippydog
| Posté Sun 11 May 08 @ 18:34:07 |
| cstoll wrote : | | No. The Network sync is for networking 2 instances of VirtualDJ together between 2 computers for use. |
What exactly is networked? I have no clue what this means :) LOL and the manual doesnt help in this regard..
Does it just basically enable a person to "sync" the BPM's? (instead of just between players it will now also "sync" the BPM's between "instances")
thanx!
| - Poster un nouveau Message - |
