Login :     Password :     Remember me
Forum: Hardware Technical Support - Topic: Some general info about Hercules DJ Console MK2 - Page: 1
Please post here all questions or comments about the hardware used with Virtual DJ, Numark Virtual Vinyl, Numark Cue or AtomixMP3:
  • DJConsole package
  • XP10 controller
  • Total Control
  • DAC / DMC-2
  • Timecoded Vinyl
  • ...and all other supported hardware
  • Hardware products
    Virtual DJ forums
      Some general info...
    - Post a new Message -
    Page : [>] [>>]
    Author - Topic: Some general info about Hercules DJ Console MK2 -
    cioce
    Ultra-VIP Member
    Posted Sat 07 Apr 07 @ 18:50:20
    Latest Hercules Console Driver download link
    Hercules MK1-MK2 PC Windows Xp-Vista Driver:
    ftp://ftp.hercules.com/pub/webupdate/DJMk2/2007_CMK2_2.exe
    Hercules MK2 Mac OS 10.4 (Tiger) / 10.5 (Leopard):
    ftp://ftp.hercules.com/pub/webupdate/DJMk2/HDJMK2_5_14.pkg.zip
    Hercules MP3 PC Windows Xp-Vista Driver:
    ftp://ftp.hercules.com/pub/webupdate/DJMP3/2007_CMP3_1.exe
    Hercules MP3 Mac OS X 10.3 (Panther):
    ftp://ftp.hercules.com/pub/webupdate/DJMP3/HDJMP3_Panther_3_92.pkg.zip
    Hercules MP3 Mac OS 10.4 (Tiger) / 10.5 (Leopard):
    ftp://ftp.hercules.com/pub/webupdate/DJMP3/HDJMP3_4_02.pkg.zip
    Virtual DJ Performances setup right to have good sound with console setted in "Use Jogs for scratch" mode
    Internal mixer mode (Standard use with Headphone connected to the Console)
    External mixer mode (With Headphone connected to an external mixer)
    Step 1
    Step 2
    Go in option and select Crossfader > Disabled
    Now if crossfader is linked to video you can use only to crossfade the video but no audio.
    Step 3 (Set "Use External mixer" in english)
    Ps. Any restart of Virtual DJ require a new External mixer selection into the Hercules MK2 panel.
    How to use DJcel Hercules DJ Console mapper
    Download mapper here http://www.virtualdj.com/addons/tools.html and If you want to VDJ auto load mapper any restart set it like this picture
    How to improve latency for Time Code use
    Donwload and install Asio4All universal ASIO driver from http://www.asio4all.com
    Set Virtual DJ Sound Setup option like this image then click on Asio config button
    Into Asio4All window select Hercules MK2, click enable and set Asio Buffer size to 128 Samples then click close window.
    After this go to the Performance tab in Virtual DJ Option and choose Latency 128 (2ms) then click Ok.
    Thanks to Skyfxl http://www.virtualdj.com/blog/skyfxl/ and to DJcel http://www.virtualdj.com/blog/djcel/
    DJ Marcel_1
    Experienced professional user
    (VDJ Radio DJ)
    Posted Sun 08 Apr 07 @ 00:30:17
    Clear and Concise. Just what a lot of VDJ/MK2 users needed.
    aledjo
    Home edition user
    Posted Sun 08 Apr 07 @ 01:36:11
    sorry but 2007_CMK2_2 isn't for win xp!
    i had tested new drivers 1.cmk2.2007 & 2.cmk2.2007 in windows xp with my hercules mk2
    end i had the same problems!
    with jog, headphones, end general....
    with old drivers 2006 the mk2 work rightly!
    after upgrade to drivers 2007, the firmware is 13.6.
    with drivers 2006 the firmware is 12.6
    in website of hercules, says 13.7!
    why??
    with drivers 2007, the jog without "overlock" not work normaly
    but with drivers 2006 work, with "overlock" end without "overclock"!
    why?
    (sorry for my bad english)
    cioce
    Ultra-VIP Member
    Posted Sun 08 Apr 07 @ 17:45:27
    Have you installed latest version 3.4.1 DJ console edition? Download here http://www.virtualdj.com/update.html
    aledjo
    Home edition user
    Posted Sun 08 Apr 07 @ 23:32:13
    yes and i tested with a friend on vdj 4.2! same problems..
    djdeep44
    Professional edition user
    Posted Wed 11 Apr 07 @ 03:33:37
    can you please explain if I can scroll through files and select a track to load using my Console. Is there anywhere a set of instruction as to how to download mapper?
    cioce
    Ultra-VIP Member
    Posted Wed 11 Apr 07 @ 05:19:07
    http://img157.imageshack.us/img157/3259/immaginexs7.gif
    Direct link for mapper download http://www.virtualdj.com/addons/download.html?addon_id=3036
    razzy666
    Home edition user
    Posted Sat 26 May 07 @ 01:22:22
    plz help me, im having trouble downloadin all the software for vdj3 and dj console mk2
    cioce
    Ultra-VIP Member
    Posted Sat 26 May 07 @ 11:36:35
    You can't download DJcel mapper because is only for Professional user (3 stars), if you want to be PRO http://www.virtualdj.com/purchase/discount.html ;)
    D-Rell
    Home edition user
    Posted Wed 30 May 07 @ 17:27:35
    for some odd reason on my hercules console. I cant hear anything when i switch between deck a and deck b. I can only hear when i put it on mix and when its on split only the right side plays.
    skyfxl
    Moderator
    (Numark UK Support )
    Posted Wed 30 May 07 @ 18:17:21
    what version are you using?
    spinnaJ
    VIP Member
    ((mac beta tester))
    Posted Fri 01 Jun 07 @ 01:45:46
    heya,,,just a quick question.. i think my mk2 is starting to malfunction as a soundcard.. As a hardware it still werk greats but as i use it as a a main controller n mixer , whenever i hear tru the headphone input..it sound really bad. very distorted n noisy.. ( this applies to deck a, deck b, mix n split mode).. This really pissed me off. I had this MK2 for a year plus n not really sure how to sent it for repair. This started recently after i download the 2007 drivers, which later i decided to switch back to the 2006 drivers. So any ideas?
    skyfxl
    Moderator
    Posted Fri 01 Jun 07 @ 02:06:01
    if you turn the volume up to much on the headphone it can distort how high is it set?
    spinnaJ
    VIP Member
    ((mac beta tester))
    Posted Fri 01 Jun 07 @ 02:59:45
    the headphone volume is not high.. Even at minimal set, it still distort.:(
    spinnaJ
    VIP Member
    ((mac beta tester))
    Posted Fri 01 Jun 07 @ 03:06:07
    btw .. y is it. if i want to use the asio4all now on my mk2 , it is always beyond logic.? how to trouble shoot that.. I have checked setting on my system and it is ok and not assign mk2 to use for other software , even for midi i don use the ms gs software wavetable syth, When i use the 2006 driver i can always overcame that n no problem .Now i reinstalled again the 2007 driver. , hence another problem arise again. How do i go from here?Thanks
    - Next page -
    Page : [>] [>>]
    Site map
    (C)opyright Atomix Productions 2008
    Software
    VirtualDJ
    VirtualVinyl
    CUE
    AtomixMP3
    VDJ HomeEdition
    DJC Edition
    eJay DJMixStation
    DJ-Box
    Comparison
    Features
    Screenshots
    Trial Version
    Plugins
    Software updates
    Press Material
    Developer SDK
    Timecode CD
    Skins
    Sound Effects
    Video Effects
    Samples
    Languages
    Wallpapers
    External tools
    Online Shop
    Forums
    Blogs
    Radio
    WorldMap
    Charts
    Atomix Productions
    VIP DJs
    VIP Zone
    Disclaimer
    Ask a question
    View your tickets
    Guides & Tutorials
