Forum: VirtualDJ Plugins - Topic: Plugins SDK for VirtualDJ v5.x and Numark CUE (PC & MAC)
Post here comments on the VirtualDJ Plugins (audio effects, video effects, video transitions, devices mapper, ...).
We remind you that plugins are downloadable by registered users only.
You can see and download the latest plugin here.
VirtualDJ forums
VirtualDJ Plugins
Plugins SDK for...
Author - Topic: Plugins SDK for VirtualDJ v5.x and Numark CUE (PC & MAC) -
djcel
Senior Team
Posted Sat 17 Mar 07 @ 9:21 pm
Please read this topic first:
http://www.virtualdj.com/wiki/index.php/Plugin_Guide
I advise you to use this file for better compatbility PC/MAC instead: vdjPlugin.h
// VirtualDJ / Cue / VirtualVinyl / PCDJ VJ
// Plugin SDK for Windows / MAC OS
// (c)Atomix Productions 2006-2008
// File Version: 1.3
// This file defines the basic functions that are used in all plugins.
// It defines the functions and variables needed to:
// - load and unload a plugin
// - give the infos about the plugin (name, picture, etc)
// - get the parameters automatically saved and restored between loads
// - interact with VirtualDJ (ask queries or send commands)
// - implement a custom interface
// Other functions specific to particular types of plugin can be found
// in their respective header file
#ifndef VdjPlugin_H
#define VdjPlugin_H
// Platform specific defines for compatibility Mac/Windows
#if (defined(WIN32) || defined(_WIN32) || defined(__WIN32_))
#ifndef WIN32_LEAN_AND_MEAN /* For old plugins compatibility */
#define WIN32_LEAN_AND_MEAN
#include <windows.h>
#endif
#define VDJ_EXPORT __declspec( dllexport )
#define VDJ_API __stdcall
#define VDJ_BITMAP HBITMAP
#define VDJ_HINSTANCE HINSTANCE
#define VDJ_WINDOW HWND
#define PLUGIN_BITMAP LoadBitmap(hInstance, MAKEINTRESOURCE(100)) /* For TVdjPluginInfo->Bitmap */
#elif (defined(__APPLE__) || defined(MACOSX) || defined(__MACOSX__))
#define VDJ_EXPORT __attribute__ ((visibility ("default")))
#define VDJ_API
#define VDJ_BITMAP char *
#define VDJ_HINSTANCE void *
#define VDJ_WINDOW WindowRef
#define PLUGIN_BITMAP "bitmap.bmp" /* For TVdjPluginInfo->Bitmap */
#define S_OK ((HRESULT)0x00000000L)
#define S_FALSE ((HRESULT)0x00000001L)
#define E_NOTIMPL ((HRESULT)0x80004001L)
#define MAKEINTRESOURCE(i) (LPSTR)((ULONG_PTR)((WORD)(i)))
#define CLASS_E_CLASSNOTAVAILABLE -1
#define NO_ERROR 0
#define wsprintf sprintf
#define __stdcall /* For old plugins compatibility */
typedef long HRESULT;
typedef struct _GUID {
unsigned long Data1;
unsigned short Data2;
unsigned short Data3;
unsigned char Data4[ 8 ];
} GUID;
typedef unsigned long ULONG;
typedef unsigned long DWORD;
#endif
// Standard structures and defines
struct TVdjPluginInfo
char *PluginName;
char *Author;
char *Description;
VDJ_BITMAP Bitmap;
DWORD Flag;
#define VDJPARAM_BUTTON 0
#define VDJPARAM_SLIDER 1
#define VDJPARAM_SWITCH 2
#define VDJPARAM_STRING 3
#define VDJPARAM_CUSTOM 4
#define VDJPARAM_RADIO 5
// Base class
class IVdjPlugin
public:
// Initialization
virtual HRESULT VDJ_API OnLoad() {return S_OK;}
virtual HRESULT VDJ_API OnGetPluginInfo(TVdjPluginInfo *infos) {return E_NOTIMPL;}
virtual ULONG VDJ_API Release() {delete this;return 0;}
virtual ~IVdjPlugin() {}
// callback functions to communicate with VirtualDJ
HRESULT (VDJ_API *SendCommand)(char *command,int deck); // send a command to VirtualDJ
HRESULT (VDJ_API *GetInfo)(char *query,void *result); // get infos from VirtualDJ
// parameters stuff
// call DeclareParameter() for all your variables during OnLoad()
// if type=VDJPARAM_CUSTOM or VDJPARAM_STRING, defaultvalue must be set to sizeof(*parameter)
HRESULT (VDJ_API *DeclareParameter)(void *parameter,int type,int id,char *name,int defaultvalue);
// OnParameter will be called each time a parameter is changed from within VirtualDJ
virtual HRESULT VDJ_API OnParameter(int id) {return S_OK;}
// Custom user-interface
// Create a Window using CreateWindow() or CreateDialog(), and send back the HWND.
// If you return E_NOTIMPL, the default interface will be used.
virtual HRESULT VDJ_API OnGetUserInterface(VDJ_WINDOW *hWnd) {return E_NOTIMPL;}
VDJ_HINSTANCE hInstance;
int Width,Height;
// GUID definitions
#ifndef VDJCLASSGUID_DEFINED
#define VDJCLASSGUID_DEFINED
static const GUID CLSID_VdjPlugin = { 0x2e1480fe, 0x4ff4, 0x4539, { 0x90, 0xb3, 0x64, 0x5f, 0x5d, 0x86, 0xf9, 0x3b } };
#else
extern static const GUID CLSID_VdjPlugin;
#endif
// DLL export function
#ifndef NODLLEXPORT
#ifdef __cplusplus
extern "C" {
#endif
VDJ_EXPORT HRESULT VDJ_API DllGetClassObject(const GUID &rclsid,const GUID &riid,void** ppObject);
#ifdef __cplusplus
#endif
#endif
#endif /* VdjPlugin_H */
You can find the old SDK for VirtualDJ v4.x and Numark CUE (only PC) here:
http://www.virtualdj.com/addons/tools.html
> In the old SDK, I have included a DSP example with a lot of comments and a .dll which enables you to get the whole list of queries used by the function GetInfo()
( see the post in this forum relative at the function GetInfo() )
> The actions used by the function SendCommand() are always the ones listed in the Keyboard Shortcuts in VirtualDJ
> Decks in VirtualDJ:
#define PLUGIN_DECK 0
#define LEFT_DECK 1
#define RIGHT DECK 2
> Frequency used in VirtualDJ:
#define SAMPLING_RATE 44100
> Here is a list of the functions used in VirtualDJ v5.2:
#define MAX_FUNCTIONS 219
LPCSTR g_szFuncNames[ MAX_FUNCTIONS + 1 ] =
// Default:
"nothing",
// Functions:
"add_favoritefolder",
"add_filterfolder",
"add_virtualfolder",
"adjust_cbg",
"adjust_cbg4",
"auto_crossfade",
"automix",
"bass",
"bassfader",
"beat_juggle",
"beatlock",
"browser_gotofolder",
"browser_open",
"browser_sort",
"browser_switch",
"browser_toplaylist",
"browser_tosidelist",
"browser_updown",
"clone_deck",
"close",
"crossfader",
"crossfader_behavior",
"cue",
"cue_stop",
"delete_cue",
"dmx",
"dmx_black",
"dmx_chase",
"dmx_color",
"dmx_flash",
"dmx_setvalue",
"dmx_strobe",
"edit_bpm",
"edit_comment",
"edit_cuename",
"effect_activate",
"effect_button",
"effect_redraw",
"effect_select",
"effect_select_multi",
"effect_slider_1",
"effect_slider_2",
"effect_slider_3",
"effect_slider_4",
"effect_slider_5",
"empty_buffer",
"eq_reset",
"file_info",
"free_playlist",
"free_sidelist",
"gain",
"goto_cue",
"goto_folder",
"goto_last_folder",
"goto_mixpoint",
"headphone_crossfader",
"headphone_mix",
"headphone_volume",
"hide_pannel",
"high",
"highfader",
"hold",
"hotcue",
"invert_icdx",
"jogwheel",
"key_lock",
/* "key_offset", */ // removed in v5.1
"kill_bass",
"kill_high",
"kill_medium",
"level",
"load_fromplaylist",
"load_fromsidelist",
"load_sample",
"loadsamplefile",
"lock_pannel",
"loop",
"loop_in",
"loop_length",
"loop_move",
"loop_out",
"loop_select",
"loop_shift",
"master_tempo",
"master_volume",
"maximize",
"medium",
"mediumfader",
"menu",
"mic_volume",
"minimize",
"mix_now",
"mix_now_nosync",
"noduplicates",
"nudge",
"onlynew",
"pannel",
"pause",
"pause_stop",
"pitch",
"pitch_bend",
"pitch_reset",
"play",
"play_n_loop",
"play_pause",
"play_stutter",
"playlist_options",
"plugin_changepage",
"randomize",
"record",
"record_config",
"record_cut",
"recurse_folder",
"reloop",
"repeat_playlist",
"reset_xp10",
"reverse",
"sample_options",
"sample_play",
"sample_rec_jingle",
"sample_rec_loop",
"sample_select",
"sample_stop_all",
"sample_volume",
"sample_volume_1",
"sample_volume_2",
"sample_volume_3",
"sample_volume_4",
"sample_volume_5",
"sample_volume_6",
"sample_volume_7",
"sample_volume_8",
"sample_volume_9",
"sample_volume_10",
"sample_volume_11",
"sample_volume_12",
"save_playlist",
"save_sample",
"saveregistryconfig",
"scratch",
/* "scratchwheel", */ // removed in v5.1
"search",
"search_options",
"seek",
"select",
"set_cue",
"set_mixpoint",
"set_scratchlatency",
"settings",
"setusercrossfade",
"shortcut",
"show_pannel",
"skip_beat",
"smart_loop",
"smart_seek",
"song_pos",
"stop",
"switch_sidelist_playlist",
"sync",
"sync_nocbg",
"timecode_active",
"timecode_bypass",
"timecode_mode",
"unload",
"vfolder_fromplaylist",
"video_crossfade",
"video_fx",
"video_fx_button",
"video_fx_param",
"video_fx_param_2",
"video_fx_param_3",
"video_fx_param_4",
"video_fx_param_5",
"video_open",
"video_select_fx",
"video_select_fx_multi",
"video_select_trans",
"video_trans",
"video_trans_button",
"video_trans_param",
"video_trans_param_2",
"video_trans_param_3",
"video_trans_param_4",
"video_trans_param_5",
"videosound_start",
"videosound_stop",
"view_options",
"zoom",
// v5.0 rev.4
"mix_next",
"mix_next_sidelist",
/* "wheel", */ // removed in v5.1
/* "wheelmode", */ // removed in v5.1
"browser_tovfolder",
"crash",
// v5.0 rev.5
"clone_deck_nopitch",
// v5.0 rev.6
"auto_mix_next",
"auto_mix_next_sidelist",
// v5.0 rev.7
"automix_skip",
"effect_slot_activate",
"effect_slot_select",
"load_filepath",
"master_balance",
"crossfader_hamster",
"video_link",
"video_unlink",
"log_search",
"pitch_range",
"multibutton",
"multibutton_select",
// v5.1
"beat_tap",
"key",
"key_smooth",
"smart_play",
"smart_cue",
"effect_slot_scroll",
"scratch_wheel",
"scratchweel_touch",
"vinyl_mode",
// v5.2
"browser_back",
"browser_enter",
"effect_slot_unscroll",
"video_fadetoblack",
NULL
> You can create "asynchronous" sound plugin (the sound plugin still works even if the button stop is pushed) by using the following flag:
infos->Flag=VDJPLUGINFLAG_PROCESSSCRATCH;
In this case, the input audio buffer is called after the pitch instead of before. So such a plugin has directly access to the final buffer which has a constant size of "latency" samples (except during loop where the buffer size is 64 samples)
djcel
Senior Team
Posted Sat 19 May 07 @ 5:03 pm
In order to use the wizard in Visual Studio 2005, all you need to do is the following:
1) Install wizard (VdjDspWizard.exe) as per normal.
2) Copy the "vdjdspwizard" directory under "C:\\Program Files\\Microsoft Visual Studio .NET 2003\\Vc7\\VCWizards" to your VS2005 installation directory, which by default is "C:\\Program Files\\Microsoft Visual Studio 8\\VC\\VCWizards".
3) Copy the "VirtualDJ" directory under "C:\\Program Files\\Microsoft Visual Studio .NET 2003\\Vc7\\VCProjects" to your VS2005 installation directory, which by default is "C:\\Program Files\\Microsoft Visual Studio 8\\VC\\vcprojects".
4) Edit the "vdjdspwizard.vsz" file ("Open with..."+NotePad) located in "C:\\Program Files\\Microsoft Visual Studio 8\\VC\\vcprojects\\VirtualDJ" and replace this line
Wizard=VsWizard.VsWizardEngine.7.1
with this line :
Wizard=VsWizard.VsWizardEngine.8.0
Do not modify this line:
VSWIZARD 7.1
_____________________________________________________________________________________
PS:
You can update the C++ files of the SDK in this folder:
C:\\Program Files\\Microsoft Visual Studio 8\\VC\\VCWizards\\vdjpluginwizard\\Templates\\1036
Site map
(C)opyright Atomix Productions 2008
Software
VirtualDJ Pro
VirtualVinyl
Numark CUE
AtomixMP3
VDJ HomeEdition
DJC Edition
eJay DJMixStation
DJ-Box
Features
Screenshots
Trial Version
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Sound Effects
Video Effects
Samples
Languages
Grafx
Tools & Drivers
Forums
Users Network
Wiki
Radio
Atomix Productions
VIP DJs
Disclaimer
Ask a question
View your tickets
Wiki
