Forum: General Discussion - Topic: the ultimate guide to controllers , which ones right for you , and tech help :) - Page: 1
Anything about Virtual DJ, Numark Cue, Numark Virtual Vinyl, AtomixMP3, etc... or not about them*
This a general discussion. Please be polite and speak with respect.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
VirtualDJ forums
General Discussion
the ultimate...
Page : [>] [>>]
Author - Topic: the ultimate guide to controllers , which ones right for you , and tech help :) -
skyfxl
Experienced pro user
Posted Wed 15 Nov 06 @ 3:45 pm
Welcome to the Ultimate Controller guide Version 1.
Controlers allow direct control over the software making it easyer to use and gives a feeling of extra realism
Lets take a moment to look at what a supported controller is
A supported controller is one which is midi enabled
Such as this
this example is a mk2 midi mixer and soundcard
non midi mixers are not contolers sorry..
The main supported controllers are
  • MK2 Console
  • Mk1 Console
  • DM2 Controller (supported in 3.4 with a external tool)
  • Xp10
  • DMC1
  • DAC2 / 3
  • D vinyl control
  • mp3 control
  • Uc33e Mixtable
  • NU04 contoler
Time code:
In-depth guide coming soon
Basics:
To use time code you need a ASIO SOUND CARD
Ie maya 44 usb
Udj45
Or mk2 dj console
Or presonus firebox
or
Virtual vinyl coming soon
Next you need :
Time code vinyl : http://www.virtualdj.com/products/timecode/
Or for cd users
Time code CD : http://www.virtualdj.com/products/timecode/VDJTimeCode.mp3
More coming soon..
Now back to controllers
There are 3 types entry level , pro level , sample control
Entry Level Controllers
  • MK2 Console
  • Mk1 Console
  • mp3 control
Mk2 Console
The Hercules DJ Console Mk2 includes:
• 2 vinyl-style jog wheels for spinning and scratching, with finger grips for rapid, accurate song searching or speed up or slow down tracks
• 1 crossfader for seamless mixing between the two decks
• 2 volume sliders
• 2 pitch knobs + 2 pitch bend buttons
• 2 x 4 buttons to control software playback (Play / Cue / Next / Previous for each deck)
• 2 x 3 equalizer knobs
• 2 x 3 buttons for effects
• 2 x 2 buttons to control the tempo (Auto-Beat and Master tempo for each deck)
• 1 ministick with 2 buttons emulating a mouse to navigate within any menu
• 2 buttons to select the audio source on the deck
product description :
The DJ Console Mk2 is at the same time a mixer, a controller for VirtualDJ, and a multi-channel USB soundcard.
It can be used with timecoded vinyls, but can also mix external analog audio sources.
Its affordable price and small dimensions make it the best solution for bars or mobile DJs.
this diagram shows how to setup the console with an external mixer
in sound config select external mixer and pick right as ¾ and left as 1/2
if you do not wish to use one simply do not connect it
to use time code
read this guide
http://www.virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
the mk2 comes with home edtion bundled with it
to see what features are not available http://www.virtualdj.com/products/comparison.html
and to upgrade for a discount
http://www.virtualdj.com/purchase/discount.html
For a mapper to adjust the buttons if you are a pro user
http://www.virtualdj.com/addons/download.html?addon_id=2509
Mk1 Console – is no longer sold
you may still find it on ebay for sale it works in a very similar way however if you buy it on ebay the software should not be included as this illegal
for a copy of virtual dj
Mp3 Control
Same as mk2 minus a souncard
The Hercules DJ Control MP3 is perfect for digital DJs and music fans right across the board:
Compact and portable, the DJ Control MP3 is a dual-deck controller for mixing MP3s, WAVs, WMA etc on a PC.
With all of these features, DJ Control MP3 is the solution DJ mixing amateurs have been waiting for. Up until now, those interested in DJ mixing have been obliged to resort to semi-professional or professional DJ hardware, or use mixing software: software which requires practice and agility in order to progress beyond automatic mixing, with only a mouse and keyboard available to control the music.
All you need to get the most out of DJ Control MP3 ia a computer equipped with a 5.1 sound card, amplified speakers and your favourite music (whether CD-Audio, MP3, WAV or WMA files).
Compact and powered directly by the computer’s USB port, DJ Control MP3 can be used with either a desktop or laptop computer, to mix your music anywhere you like! DJ Control MP3 can also be used to control other mixing software via MIDI commands sent to the computer.
to use headphones
you need a 5.1 soundcard and you need to select headphone mode in the sound setup , and select one output as headphones and one as preview
the software is once again bundled with home edtion
to use the full features of the console you need to upgrade
Dm2 mixer
this contoler costs 30 pounds and is a great starter it only works with 3.4 pro
http://www.virtualdj.com/forums/50725/New_features/mixman_DM2_Support_.html
to gain the files needed to operate it
found on the web
supports song selection beat lock , and cross fade and basic scratching
at this time the shortcuts do not work well however Im attempting to solve this and will post a new file soon
high end controllers
  • Xp10
  • DMC1
  • DAC2 / 3
  • D vinyl control
  • Uc33e Mixtable
  • NU04 controller
Xp10
allows advanced control and has a soundcard
can work as a single or a pair check more info here:)
http://www.virtualdj.com/products/xp10/
DMC1 + DAC
DAC controllers are rackable USB remote controllers specially designed for computer DJs.
They offer all the standard features of traditional CD remotes (pitch, play/pause, cue, time display, etc...), plus a few specific to VirtualDJ.
At this time only Dac 3 is sold
But you can find the old ones on ebay , new or old they do not come with vdj
But with pcdj limited edition which in my opinion is so poor you might as well chuck it
You have to purchase it here
a mapper (dac3) for 3.4 is available here
http://www.virtualdj.com/addons/download.html?addon_id=2401
dac 2
http://www.virtualdj.com/addons/download.html?addon_id=2178
Specifications FOR DAC 3
• Fast USB 2.0 plug'n'play connection.
• 3U standard, 19" rackmount unit.
• MIDI compatible.
• Easy to use interface for any DJ.
• Looks, feels and operates just like any standard dual CD Player.
• One button beat match.
• One touch looping.
• Slider control for Pitch and Volume.
• 'Mix now' button for smooth cross fade into the next track.
• Single button instant reverse.
• One touch direct cue point access.
• Play, sample or loop in reverse.
• One touch complete effects control.
• Create loops and cue points on the fly - perfectly synced every time!
• Clear displays for players A and B.
• True instant start - no delay!
• Jog wheel to search & load songs in the recordcase and set cue points.
• Lockable Pitch for both players - ensures rock-solid sync every time!
• No need for mouse or keyboard.
• 12 volt UK power supply.
Next generation digital audio controller!
Our brand new DAC-3 is a high-end, rackmountable 19" hardware control unit, designed by and purpose-built for today's working DJ. In fact, the DAC-3 is just as impressive when used by any live performer, looking to exploit the latest in digital mixing software technology!
Plugging straight into your PC or laptop via any standard USB connection, the DAC-3 gives DJs the ultimate in rock-solid, real-time feel - with lightning fast results. And now with the exciting addition of industry-standard MIDI support, the DAC-3 is ready to go with any MIDI compatible software - straight out of the box!
So, whether it's a digital DJ program or Live Sequencing application, the DAC-3 will finally give you all the hands-on tools needed to make your set the professional performance it was always meant to be - without the need for a clumsy keyboard or mouse.
Take a bold step into the future. With super cool, blue LCDs and that now unmistakable PCDJ look and feel, the new DAC-3 controller is the ultimate solution for any seasoned or aspiring digital performer.
Key Features:
• Successor to the massively popular DAC-2.
• Suitable for any user of MIDI-compatible digital mixing, live performance or music production software (PCDJ, Ableton Live, ..).
• Larger 3U design, for even greater hands-on control.
• USB 2.0 connection with still faster response times.
• Distinctive & cool, twin Blue LCDs.
• In research & development for over 12 months
D Vinyl Control
Product Description
Vinyl, MP3 files, CD’s, turntables, and digital effects, DJ’s want to use them all and with the new Soundgraph D-Vinyl 2020 you can! That’s because the D-Vinyl 2020 is a complete hardware AND software package that combines a full blown 3-rack space DJ controller with mixer, dual jog wheels, slider and switch controls, and an integrated USB sound card with all the interface software needed to play MP3 files, CD’s, and even your favorite records.
Here’s the deal; the D-Vinyl has 3 Playing Modes: Digital Vinyl Mode allows you to play and control MP3 files stored on your computer’s Hard Drive with conventional turntables or CD players and use all your performance moves like CUEing, backCUEing, scratching, fast/slow spinning, etc. MP3 Mode allows you to play and control MP3 files right from the 2020 controller without having to use a mouse or keyboard (up to 99 songs in each playlist). Analog Vinyl Mode lets you control your turntables and CD players and play your vinyl or CD collection using only the hardware controller just like in a conventional turntable/CD setup.
The D-Vinyl is compatible with Windows 98SE, 2000, ME, and XP so there is no need to install Linux or another operating system into your computer. All software features (play, pitch shift, beat sync, cue, loop (20cues and 20 loops per MP3), edit, track search, search/load while playing, and much more can be accessed directly by the controller so you can keep spinning instead of typing. 6 pair RCA inputs with dual phono preamps, Type A and B USB ports. See, you can have it all!
D-Vinyl2020™ H/W is a latest dual CD player type controller for the whole operation of S/W and the interface device to connect with computer and the current DJ devices like turntables and mixer. No necessary to use keyboard or mouse during your gig. All the controls with Jog wheel, Buttons, Sliders and LCD display in D-Vinyl2020™ H/W. Without turn-table or CD player, D-Vinyl2020™ H/W works also as a stand alone controller for the remix of MP3.
Software
D-Vinyl2020™ software provides 3 applications: Dual MP3 Player™, Playlist Editor™, MP3 Editor™.
Major functions of D-Vinyl2020™ are Spin MP3 with Turntable or the latest CD player
AUTO/MANUAL/PRE Beat Counter
Effects-CHOP, AUTO PAN, EFFECT, VINYL SIMULATOR
Pitch Controls by +/-8%, +/-12%, +/-25% or +/-100%
Never Shock or Skip
Saving 20 CUE/LOOP points per Each MP3 File
Recording your remix as .wav in real-time
Professional [2IN/4OUT] USB Internal Soundcard
Playing Normal Vinyl
D-Vinyl™ Record
The record has a special frequency signal in the groove in order to receive the dynamics of the turntable for the control of MP3s from your HDD like scratching. So, you can put this specially designed digital vinyl on your normal turntable, with a normal needle, then you can play MP3 in D-Vinyl2020™ software with the real touch of vinyl. Also with the Audio CD supplied by D-Vinyl2020™, you can connect the CD Player with D-Vinyl hardware like the CDJ1000 to control MP3 with your CD player. If you put normal vinyl on your turntable instead of this Digital Vinyl, you can also play it under the Analog Vinyl Mode in D-Vinyl2020™ hardware.
Technical Info
System Requirements
OS: Windows 98SE, ME, 2000 and XP
CPU: Pentium III 550 MHz or higher (Recommended Pentium III 866 MHz or higher, and Pentium IV 1.4 Ghz or higher for XP users)
RAM: 128 Mb or higher
HDD: 30 MB for install S/W, additional space for MP3 store
USB: More than one port.
Highly recommended: Intel and VIA USB Host Controller
Sound Card: No Sound Card needed (D-Vinyl H/W has dual USB SoundCard)
Graphic Card: More than 1024 x 768 resolution
DirectX: DirectX 8.1 or higher
Mapper 3.4:
http://www.virtualdj.com/addons/download.html?addon_id=2308
NU04 midi mixer
“The NUO4 mixer from Ecler is a professional mixer that can control VirtualDJ directly, thanks to its MIDI commands.
It is of great interest to DJs who mix video, since its crossfader will also control VirtualDJ's video crossfader.”
This controller is a mixer in its own right which can sync with the software while you mix
“This revolutionary 4 channel mixer featuring control of external devices via MIDI, allows deejays to play software live in a natural and intuitive manner. This remote controller features 72 different MIDI messages, which can be fully programmed to your choice and customized later on with an innovative label print system.
The NUO4 concentrates to control of a computer in a traditional mixer and so allows laptops to coexist at deejay booths with turntables and CD decks, so bringing deejays an open window to the future of live music mixing and production...”
Mapper for 4.1
http://www.virtualdj.com/addons/download.html?addon_id=2511
samples mixer
The UC33e gives you a set of 9 faders that will reveal the true power of the new sample machine of Virtual DJ.
All the knobs and buttons can also be assigned as midi shortcuts to drive any function you want in VirtualDJ.”
So you can fire of samples at the touch of a button
Which controller is right for me ?
you need to consider your pc specifications :
(the more ram you have and the faster processor the better these controllers will operate)
you need to consider the cost :
if you are on a tight budget and you’re a home user get a dm2 and use 3.4 or even better an herc mp3 control console
if you are a pro user on a tight budget get the mk2 It’s a dependable platform for time code it’s a good soundcard and a stable midi mixer
if you are a pro user on a slightly generous budget
get two xp10s or a DAC 3
example xp 10 and and dac 3
example dac 3 system
if you are looking for sample control get the uc33 mix table and another controller dac 3 or xp10 maybe
if you want the control in a more traditional form on a mixer get the NU04 or if you want to mix video
if you want a very advanced control system and a time code
get the D-vinyl control
The End
I hope this guide proves useful I will be adding extra information as I discover it :)
If you need help
Contact admin@skyfxlmedia.com
This is also an msn address
This is todays guide more will follow 2 morrow or later today :)
Niems
Professional edition user
Posted Wed 15 Nov 06 @ 7:48 pm
I have searched everywhere, but I cannot find a store that sells the D-Vinyl controller. Any help?
All the stores i find are old discontinued archives
skyfxl
Posted Wed 15 Nov 06 @ 8:15 pm
il have a looksey for you
have u tried ebay :)
juliocqb
VIP Member
Posted Wed 15 Nov 06 @ 8:22 pm
I've found one link for you my friend...
http://www.bizrate.com/keyboardsmidi/oid497047478__nwylf--.html
Dj Quintana
skyfxl
Posted Wed 15 Nov 06 @ 9:04 pm
nice one :)
l_rids
VIP Member
Posted Wed 15 Nov 06 @ 9:21 pm
Looks like someone is moving closer towards VIP status ;)
xeon
VIP Member
Posted Thu 16 Nov 06 @ 9:40 am
good one ;) maybe a sticky?
skyfxl
Posted Thu 16 Nov 06 @ 10:26 am
its a sticky in the main guides section :)
will add bcd2000 info soon:)
A Man and His Music
Ultra-VIP Member
Comedy Central Inc.
Posted Fri 17 Nov 06 @ 12:39 am
Very good job. Not to nitpic, but a couple of times you say DAC 3, but show a DAC 2.
skyfxl
Posted Fri 17 Nov 06 @ 11:27 am
oopsi lol
Niems
Posted Fri 17 Nov 06 @ 1:23 pm
Thanks hey juliocqb!!
Just out of interest, does anyone know if the D-vinyl controller is more advanced than the DAC-3? That website gives it a crap rating. Guess the DAC is more frequently updated in terms of its mappers and stuff
Superstom
Ultra-VIP Member
Posted Fri 17 Nov 06 @ 3:04 pm
The d-vinyl 2020 is discontinued. You probably could find it second hand. But I would get the dac 3. The is a very good mapper for the dac 3 (thanks to jpboggins). The is not a mapper for the d-vinyl.
I use the d-vinyl on most of my gigs and I like it very much.
I dont like second hand dj gear so if I didn't had it, I would buy a dac3.
If you don't need an 19Inch especially, I would go for the Numark iCDX.
Little correction. It is not possible to use the VDJ time code vinyls with the builtin sound card of the d-vinyl 2020. This controller has just 2 inputs. These are used mono with the d-vinyl time code vinyls. But you don't have needle drop in mono. If you would use timecode with a 19Inch controller, you probably better could go for the Dac3
Ewout
discobrian24
Moderator
Posted Sat 18 Nov 06 @ 1:12 am
Hey sky don't forget to add the X-Session as it is a great midi mixer/tool.
skyfxl
Posted Sat 18 Nov 06 @ 1:13 am
il do some research on it :) thankies :)
rice4u
Limited edition user
Posted Sat 18 Nov 06 @ 7:29 am
out of curiousity, has anyone ever tried the dm2 mapper? cuz i've download it and it seemed kinda complicated. does it actually work?
skyfxl
Posted Sat 18 Nov 06 @ 11:50 am
it works for me its for 3.4 only
contact me and il help you msn : admin@skyfxlmedia.com
brickrjc
Posted Sun 19 Nov 06 @ 1:28 am
What do you think about the Allen & Heath XONE 3D for Virtual DJ ?
skyfxl
Posted Sun 19 Nov 06 @ 1:40 am
there isnt a mapper yet
but if u make an xml file it should be amazing
its a wonderful bit of kit from what iv seen :)
Niems
Posted Sun 19 Nov 06 @ 10:31 am
Superstom, I have found a place that sells new ones.
There is a mapper for it in the downloads section, do you use it?
And also, I dont need the soundcard built into it at all. I already have a U46DJ for all of that
Superstom
Ultra-VIP Member
Posted Sun 19 Nov 06 @ 4:23 pm
Mapper? I must have missed it. I will download it, try it and post the results. Thanks for this tip.
Could you post the information about this "place" or send it in a private message? I would like to have another one for my small setup and one spare unit.
The soundcard is ok for output. I use this output when I do not use timecode. If I use timecode I use a Maya usb. I will upgrade to a Rme Fireface 400 soon.
If you already have a proper sound card already or not use timecode, then the D vinyl 2020 is a good controller. The jogs work very accurate and good and the buttons also work pretty good.
Ewout
Page : [>] [>>]
Site map
(C)opyright Atomix Productions 2008
Software
VirtualDJ Pro
VirtualVinyl
Numark CUE
AtomixMP3
VDJ HomeEdition
DJC Edition
eJay DJMixStation
DJ-Box
Features
Screenshots
Trial Version
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Sound Effects
Video Effects
Samples
Languages
Grafx
Tools & Drivers
Forums
Users Network
Wiki
Radio
Atomix Productions
VIP DJs
Disclaimer
Ask a question
View your tickets
Wiki
