Forum: Music discussion
Topic: The Ultimate Guide to Broadcasting With Virtual Dj - Page: 4
dxflwHome userMember since 2006
a friend of mine has the pro version. how can i do it directly from the virtual dj to push a button when i want to talk and the music decreases?
Posted Mon 25 Jun 07 @ 8:36 pm
sbangsPRO InfinityMember since 2004
you need it your not allowed to use his copy
enable talk over on the console soft and when you turn the mic on by pressing the button it is reduced
i hope to see you as a pro user soon
Posted Mon 25 Jun 07 @ 8:40 pm
we want to broadcast from my friends computer, he doesn't own hercules and he wants to do it directly from vdj so please someone answer my simple question. thanks
Posted Tue 26 Jun 07 @ 2:13 pm
he should use his acount to ask then..
Posted Tue 26 Jun 07 @ 2:21 pm
why you just can't answer my question?
Posted Wed 27 Jun 07 @ 12:03 pm
anyone please?
Posted Sat 30 Jun 07 @ 10:54 am
billy_44ControlleristMember since 2007
how do u broadcast?
Posted Thu 02 Aug 07 @ 3:01 am
dydy1PRO InfinityMember since 2006
Can one use Mac Virtual DJ for broadcasting too?
Posted Thu 02 Aug 07 @ 5:04 am
billy_44 wrote :
how do u broadcast?
check page one of this guide
Posted Thu 02 Aug 07 @ 12:34 pm
yes its all the same setup :)
PFD50PRO InfinityMember since 2007
Sky
I have opened ports in windows firewall and I just have a USB modem.
When I try to broadcast it says "Error" "can't listen on port 8000"
Any ideas what I can do next.
Posted Sat 04 Aug 07 @ 10:49 pm
who is your carrier? they can block ports on their end too
for example aol ban server ports unless you request them.
Posted Sun 05 Aug 07 @ 12:22 am
msalmonPRO InfinityMember since 2005
You may have to purchase a modem/router, I am not sure if usb modems can be configured as your requirements.
Mike
Posted Sun 02 Sep 07 @ 6:43 pm
K15HY DHome userMember since 2006
Can anyone help me , i am trying to broadcast using mk2 console and virtual dj. I try to use Shoutcast at which point i see that a Encoder is required. I don't know what should used in the Encoder section. I am running through a netgear modem router on a broadband connection, i see everyone mentioning port openeing, but i am assuming this is only used for streaming to a server which i do not want to do. Would appreciate some help
Posted Tue 11 Sep 07 @ 6:58 pm
Posted Tue 11 Sep 07 @ 7:05 pm
i have downloaded the encoder and saved it to the path file you saved it but i can't seem to find it when iam looking in virtual dj folder, and nothing goes into my encoder section
Posted Tue 11 Sep 07 @ 7:15 pm
do you think i need winrar to open the encoder as it comes as a zipped folder
Posted Tue 11 Sep 07 @ 7:18 pm
yes extract that and copy the lame.dll to the virtualdj program folder
Posted Tue 11 Sep 07 @ 7:56 pm
I have put the .dll into virtual dj and that has changed the end of the link to virtual dj.mp3 ,but i still cannot log to the link is there anything i need to be changing on my router and if so does it affect my day to day normal use of the internet ?
Posted Tue 11 Sep 07 @ 8:30 pm
look in the config and forward ports 8000 and 8001
do the same in the firewall :)
Posted Tue 11 Sep 07 @ 9:21 pm
54%
