Forum: Old versions
Topic: Guide To set up tcv with mk2 console :) - Page: 2
briskoHome userMember since 2004
Can i only put 1 TT on the MK2 to control Deck A & B, because in the Virtual DJ Options you can choose "Single Timcode"?
But i cant imagine how this should work. What can i do with this TT then? Controle the active Deck?
And what do i have to connect with the cables?
A third image for showing us how to do this with one TT would be very nice!
I hope you can help me =/
Thx, Dennis
Posted Sat 02 Dec 06 @ 2:18 am
sbangsPRO InfinityMember since 2004
im sorry but your copy of home edtion can only support a single timecode for a short amount of time
for more you need to upgrade to pro edtion
Posted Sat 02 Dec 06 @ 10:46 am
I want to know it because i want to buy the Pro, but first i want to have an overview what i must buy and what not and what for functions i have then.
Sry my English isn`t very well. I hope you understand what i want to say. ^^
Thx
Posted Sat 02 Dec 06 @ 12:34 pm
you need
2 x timecode tinyl or cd
a soundcard which supports this
needs two stereo inputs
and pro
and your good to go :)
Posted Sat 02 Dec 06 @ 1:55 pm
lol :D ^^
the problem is i only have one TT atm and want to know how i can use Virtual DJ with only ONE TCV
Im want to setup this with the Trial Version.
And what i can control with the one TT then?
This cant be so difficuelt to answer xD
ThX!
Posted Sat 02 Dec 06 @ 3:49 pm
u can control either DECK A or DECK B
and u can choose bettween A or b using keyboard shortcuts
Posted Sat 02 Dec 06 @ 4:23 pm
Ah thx :D
I saw it myself as i choosed "Single Timecode" - there were this little bubbles :D
thx ^^
Posted Sat 02 Dec 06 @ 6:21 pm
any time :)
Posted Sat 02 Dec 06 @ 6:24 pm
skyfxl wrote :
please reinstall your console edtion software
and the mk2 drivers
tried that ;<
Posted Sat 02 Dec 06 @ 11:15 pm
have u done a hard uninstall ?
uninstall
then
go to run and type regedit
on this screen go to find and type virtual dj
and delete all the keys
then reinstall
Posted Sat 02 Dec 06 @ 11:17 pm
cjoe73PRO InfinityMember since 2021
hi guys some one can help,i have everything working good but is only one step more to be set with my timecode vinyls,i have my mk2 hercules dj console connected to a external mixer,and also i have my two turntables connected to the mk2 so the turntables from the mk2 connected to my external mixer so now just wanna play one deck at time to mix my music because when I'M playing one side and wanna play the other side both play at the same time so just wanna do it like regular mixer
hope you guys anderstanding me what i wanna do
thanks .. joe
Posted Mon 04 Dec 06 @ 7:16 am
hi name is ahmar
question for skyfxl
i use my cdj1000 tccd with mk2 console it works fine if i only use it for just to play songs.but when i scratch it does not work.
i use the set up you said.
if you can help me out thanks
Posted Mon 04 Dec 06 @ 7:23 am
thanks .. joe
hi chose external mixer mode on mk2 console
and external mixer
mode on sound config
1/2 left 3/4 right
Posted Mon 04 Dec 06 @ 11:02 am
ahmar824 wrote :
hi name is ahmar
question for skyfxl
could you please post a screenshot of your config remember the console edition has limited timecode support so you will need to upgrade for full use
Posted Mon 04 Dec 06 @ 11:03 am
hey..i hooked my tcv up to the hercules perfectly. BUT when i go to preview with my headphones, it wont let me hear deck a or deck b only mix.. any suggestions? i have 4.1
Posted Tue 05 Dec 06 @ 9:39 pm
choose HEADPHONE MODE
1/2 main 3/4 headphone
Posted Tue 05 Dec 06 @ 10:22 pm
headphone mode~? where is dat at? in the mk2 control panel?
i have input 1-2 for speakers and i have the headphones in the headphone jak
Posted Tue 05 Dec 06 @ 10:33 pm
Posted Tue 05 Dec 06 @ 11:02 pm
HELP ME PLEASEE!!!
from one day to another this thing has gone haywire :o(..
ok, yesterday i used my system..oerfect..i toook my radio sumwhere last night, plugged it bak in today to dj again, and there is sooo much noise comin from outside sources..the music isnt clear AT ALL.. when i go to the timecoded config in advance view, the percentage jumps around from 33, 55, 100, and keeps fluctuating.. where did this go wrong!?>?!>?> i have 2 stanton str8 100's, herc mk2, tcv, and sony viao..
thanks
Posted Thu 14 Dec 06 @ 8:23 pm
so ur using 3.4 yes :)?
have u checked ur cable groundings?
Posted Thu 14 Dec 06 @ 8:27 pm
25%
