Forum: General Discussion - Topic: A quide to setting up BCD2000 in Virtual DJ 4.1
Anything about Virtual DJ, Numark Cue, Numark Virtual Vinyl, AtomixMP3, etc... or not about them*
This a general discussion. Please be polite and speak with respect.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
VirtualDJ forums
General Discussion
A quide to settin...
Author - Topic: A quide to setting up BCD2000 in Virtual DJ 4.1 -
dj-in-norway
Atomix Productions
Posted Sat 14 Oct 06 @ 5:18 pm
BCD2000 WDM (directX) MODE GUIDE
This is for those who dont need to run in asio (asio is first of all for timecode vinyl input users)
Also a good solution for those who run into Asio driver errors...
Thanx to Manquin for pictures!!
dj-in-norway
Atomix Productions
Posted Sat 14 Oct 06 @ 5:44 pm
BCD2000 MIDI CONTROLLER MAPPING
You can use the controller as a midi controller only (with or without the BCD2000 as soundcard)
For mapping the midi controller part, you can do so manually by adding the enclosed XML mapper file, that will set up MIDI shortcuts in VDJ. (You can change the XML code too, for your own likings)
NOTE:
- in this mode, led's on console will probably not work, or work right.
A "hardcode" mapper will come soon, made by DJ Cel, that will allow mapping of buttons of the BCD2000 on the fly while you mix. This kind of mapper will work just as the default native support, including led and more (like Hercules mappers). It will be released later...
MIDI SETUP
Site map
(C)opyright Atomix Productions 2008
Software
VirtualDJ Pro
VirtualVinyl
Numark CUE
AtomixMP3
VDJ HomeEdition
DJC Edition
eJay DJMixStation
DJ-Box
Features
Screenshots
Trial Version
Plugins
Software Updates
Press Material
Developer SDK
Timecode CD
Skins
Sound Effects
Video Effects
Samples
Languages
Grafx
Tools & Drivers
Forums
Users Network
Wiki
Radio
Atomix Productions
VIP DJs
Disclaimer
Ask a question
View your tickets
Wiki
