good call!
Posted Sat 05 Mar 11 @ 5:19 pm
Arkaos Grand JV now suppots VST plugins to allow for the audio from another app to control visual effects. I downloaded the arkaos VST plug in, had to place it in sound effects, it can be selected and the pop up control window shows up BUT WITH NO CONNECTION. Is Virtual DJ not allowing this type of plug in? any idea what the problem might be???? i am a licensed CUE user
THANKS
SHARYN
THANKS
SHARYN
Posted Tue 29 Mar 11 @ 1:53 am
i have the hercules MK4 dj console, i have tryed putting the dll. file in the directory everyone is talking about and im STILL not seing any effects when i load up virtual DJ help anyone....PLEASE...
Posted Thu 31 Mar 11 @ 10:44 am
Sorry, the software that you received with your DJ Console is a free limited edition and does not allow custom skins, effects, etc. to be used or the program configuration options to be changed (Except during the 20 day trial of Pro.)
To be able to use custom skins, effects and much, much more you will need to upgrade to the full VirtualDJ Professional. Your MK4 VirtualDJ LE entitles you to a significant discount off the cost of upgrading. To receive this, please go to http://www.virtualdj.com/buy/index.html
You can also try out Pro features in VirtualDJ v7 Home FREE by going to http://www.virtualdj.com/download/free.html - This software will allow you to test your MIDI controller with it for 10 minutes at a time before reverting back to internal mouse and keyboard control only.
Posted Thu 31 Mar 11 @ 1:20 pm
I have virtual DJ 7 and i cant seem to get any VST to work (DSK) they just mute my music............Any fixes out there?
Posted Fri 29 Apr 11 @ 6:32 am
DjTribal A wrote :
I've downloaded some free vst effects (minion, audjoo helix etc).All of them are in dll format. I'm a mac user and I've checked that these plug ins are compatible with OSX. The problem is that despite I put them in "sound Effect" folder, I can't use them. When I open VDJ I see nothing more than my older effects. How can I solve this problem?
Yes!
I am also a Mac user with a ton of VSTs (VSTs that work within Live, are VST1s, etc).... I can't get VSTs to work with Virtual DJ.
Suggestions!?
I really want to use Effectrix:
http://www.youtube.com/watch?v=AMFIAWtslS8
(this effect is used by Siriusmo and Shook)
Posted Sun 08 May 11 @ 12:09 am
Does anyone know if BBE's Sonic Maximizer VST plug in's work in VDJ Pro 7.0 Full Version (Windows 7, 64 bit)? I would like to use this VST sound processor for not only playback, but also during recording... It is rather expensive and comes with a very aggressive iLok code, so I would like to hear if anyone used this plug in before I drop a hundred box on something that I may not be able to use... Any comments would be appreciated!
Posted Wed 17 Aug 11 @ 5:45 pm
can so one tell me can you records your mix vides in the free verison because it not letting me what fun is it to have if you can record or what update or plug in do i need
Posted Mon 12 Sep 11 @ 1:37 pm
The answer is yes, you can record with the Home Free version.
But you are posting at an irrelevant thread. Please do a search in the forums, and if you can not locate an answer to your question, open a new thread, providing any infos regarding your issue.
Answers may also be found here http://www.virtualdj.com/wiki/PDFManuals.html
Posted Mon 19 Sep 11 @ 8:39 am
Since the intro-message here says that VST 2.0 might not be supported, I would like to encourage for the devs to update this part of VDJ - since we are now moving into the VST3 Steinberg standard.
Posted Tue 08 Nov 11 @ 11:21 am
hi i'm new here and i don't understand why i can't do anythings in this site..
"Your current licenses do not allow you to download Effects"
"You don't have access yet to any Reserved forums."
do i need to pay?? can someone help me???
Posted Fri 23 Dec 11 @ 3:21 am
You need to purchase a VDJ license appropriate for the downloads you want to access, and then register this license in your forum profile.
Posted Fri 23 Dec 11 @ 5:41 am
Hello,
I'm trying to create a small plugin for VDJ, but I need some guidance, can you please provide me with whom to contact ?
Thanks in advance.
Thanks in advance.
Posted Mon 27 Aug 12 @ 2:19 pm
Start a new thread in the plugins forum with your questions :)
Posted Mon 27 Aug 12 @ 3:53 pm
Oups, sorry...
Posted Mon 27 Aug 12 @ 4:26 pm
No problem :)
Start a completely new thread. I've replied to your support ticket too.
Posted Mon 27 Aug 12 @ 5:16 pm
