Topic: Whoops...
Finally got access to my software and after 2hrs I downloaded a skin, added it to the skin file but the program won't start and the original skin is all messed up....where di I go wrong and how do I remedy it?
Thanks
Posted Sun 31 Mar 02 @ 5:16 pm
Got the original back and working but the skin I downloaded isn't appearing in the options bit even though the file in ...program files/atomix/skins.....what is wrong?
Cheers
Posted Sun 31 Mar 02 @ 6:37 pm
you need to extract the bmp and the xml files from the .zip into your skin directory.
Posted Sun 31 Mar 02 @ 7:00 pm
Thanks, on further persistence I found that there was an error in the download(line 2) so I deleted and repeated the download and there it was!! Nice....thanks.
Do I have to adjust my monitor to fit the screen, afraid to touch unless necessary!!!
Posted Mon 01 Apr 02 @ 9:21 am
crundlePRO InfinityMember since 2003
yeah, I think you have to, I did it to mine without killing it, so anyone can!
Posted Mon 01 Apr 02 @ 2:00 pm
