I have just installed a Soundblaster Z SE sound card to replace my onboard sound, I am now getting a yellow "Warning Triangle" in the "Line Input" settings stating that i need an "Analog Mixer License". Surely this cannot be correct, any ideas please.
Posted Fri 18 Nov 22 @ 9:47 am
Post a screenshot of your audio configuration please.
However keep in mind that some aspects of the audio configuration (like using line inputs and/or timecode) are limited on controller (Home PLUS) licenses.
A Home PLUS license allows the unlimited usage of the controller and the audio setup it needs to operate.
Anything "extra" will be limited.
Posted Fri 18 Nov 22 @ 10:41 am
This is not about the soundcard itself, but about the routing configuration.
If you want to output deck1 and deck2 on two separate audio outputs, and mix them with an external analog mixer, that's a Pro configuration and requires a Pro license.
The Home free license only let you send the master and the headphone on two separate audio outputs (which is the standard home configuration)
If you have a controller with an integrated mixer, then a Plus license for this controller will only let you use the soundcard from that controller to do external mixing.
In your case, from what I understood, just make sure you select "master + headphones" in the audio config, and you should be good
Posted Fri 18 Nov 22 @ 11:19 am
I had the same message this past weekend. I have a pro license, what did you find out about this error? How do I fix it?
Posted Wed 07 Dec 22 @ 3:47 pm
It told me my Denon MC6000MKII was not supported and I will need a different license for an analog mixer. Sound routing Options didn't even offer my Denon, but it knew it was plugged in. What should I try next? I rebooted everything, logged into VDJ, it showed my Pro license at the top, but still wouldn't let me use it.
Posted Wed 07 Dec 22 @ 3:52 pm
@JOHN, your issue is probably different than the OP, as you are a Pro licensed user and you shouldnt get any warning in Audio Setup.
Start by installing the MC6000MKII Windows driver https://www.denondj.com/downloads and consult the device manual ..
https://www.virtualdj.com/manuals/hardware/denon/mc6000mkii/installation.html
https://www.virtualdj.com/manuals/hardware/denon/mc6000mkii/advanced.html
If still any issue, please provide further details and/or screenshots
Posted Wed 07 Dec 22 @ 4:33 pm
