Hi
I'm having a real struggle to find out this problem on the software. I have a i5 10th gen laptop with 8GB RAM and running Windows 10 Pro . I'm using the latest version of Virtual DJ but for some reason the waveform/Graphics are so jerky at times and I don't know why. i have the FPS set to 60 and math engine disabled as I don't use the stems feature and I've got my power performance set to high performance but nothing seems to be making any difference , so does anybody either have the same or similar issues and if you are does anybody know a fix for it so the graphics run smoothly. the audio on the other hand unaffected.
Posted Tue 13 Apr 21 @ 6:25 pm
Have you checked your graphics card manufacturer website for the latest drivers?
If you have two graphics cards (as many laptops do) check you are using the full power one and not discrete.
Posted Tue 13 Apr 21 @ 6:33 pm
