Reporting a possible very minor bug.
Let me try to explain the steps.
1) Start VDJ (Pro Skin have not tested w others)
2) click the highlighted blue PFL to turn it off
3) Load song on deck 1 and play track
4) Click sandbox mode and track is heard through headphones
5) Turn off sandbox mode .. headphones STILL PLAY AUDIO (with deck1's PFL button off)
the fix is to toggle deck 1's PFL button on and off,
Then sandbox mode audio is switched correctly, until the next time VDJ is restarted.
NOTE:
This works correctly from the start if Deck 2 is used first.
IE:
3) Load song on deck 2 and play track
5) Turn off sandbox mode and headphone audio is off as expected
and deck 1 will also function correctly, if Deck 2 is used first, until VDJ is restarted.
(without that toggle fix, which is needed for deck 1)
Summary:
Headphone audio does not turn off, when using Sandbox mode, after starting VDJ, when deck 1 is the first to use Sandbox mode.
Once PFL for deck 1 is toggled on and off after using sandbox mode, Sandbox mode audio works perfectly.
(Or if deck 2 uses Sandbox mode first)
I can create a video with audio.
no need to fix,
I am just reporting this possible minor bug.
VDJ ver 6294
Default Pro Skin
No controllers connected
NOTE:
IE:
Summary:
no need to fix,
VDJ ver 6294
Default Pro Skin
Posted Mon 08 Feb 21 @ 1:13 am
Exactly, i never noticed but you are right, same here. Only first time load a song (after startup VDJ) on deck 1, turning off pfl, playing in sandbox and back from sandbox still listening to pfl in headphones while pfl button off. Doesn't happen in deck 2. After second song loaded everything back to normal. It's not annoying, but indeed it looks like a buggie ;-)
(version 6294)
(version 6294)
Posted Tue 09 Feb 21 @ 1:56 pm
Thank you confirming that you could replicate this.
Again, I was just reporting this possible minor bug, and since you could replicate it, it is really there .
It is not an issue.
Wanting VDJ, to continue the be, the most Amazing DJ Software on the Planet !
It is not an issue.
Posted Tue 09 Feb 21 @ 4:02 pm
