The Script for half size loop does not work anymore, any idea how it can be fixed?
loop 2 & down ? blink 300ms & repeat_start "rsAHL" 33ms & loop 2 ? loop_position & param_bigger 90% ? set "top" 1 : var "top" 1 ? loop 1 & set "top" 0 : nothing : loop 1 ? loop_position & param_bigger 90% ? set "top" 1 : var "top" 1 ? loop 0.5 & set "top" 0 : nothing : nothing : loop 0 & repeat_stop "rsAHL
Posted Sun 18 Nov 18 @ 1:54 pm
Don't know if anything else wrong with it, but last line color in dark red is missing quote at end. Formatted with simple error check here:
http://www.tellyvisuals.com/vdjscript.php
loop 2 & down
..? blink 300ms & repeat_start "rsAHL" 33ms & loop 2
....? loop_position & param_bigger 90%
......? set "top" 1
......: var "top" 1
........? loop 1 & set "top" 0
........: nothing
....: loop 1
......? loop_position & param_bigger 90%
........? set "top" 1
........: var "top" 1
..........? loop 0.5 & set "top" 0
..........: nothing
......: nothing
..: loop 0 & repeat_stop [color=#0000ff]|"|rsAHL[/color]
Posted Tue 20 Nov 18 @ 1:44 am
