About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Switched from iTunes to MusicBee - Changed File Directory - search DB problems
So I switched music directories - caused me enough problems - but i am happy I did.
Now my search database has double the files - the old and the newly added. How can I simply remove all the files with broken links?
Posted Tue 21 Aug 18 @ 9:09 pm
clean VDJ Database.
Posted Wed 22 Aug 18 @ 12:13 am
... under the dot menu on the bottom left of the screen
Posted Wed 22 Aug 18 @ 9:08 am
