Forum: VirtualDJ 8.1 Technical Support
Topic: Need help regarding AutoMixing!
Hello people! This is my first post here. Kindly bear with me if I fail to follow any rules.
I want to do just a simple thing to the playlist of my choice. I want to play a song for a specific period of time (say 1.5 minute) and then play the next track and I want to do this for each and every song in the playlist. After searching for several hours, I still cannot find any solution. Is it doable? If yes, please give me the instructions for the same as I want it to be sorted out by tomorrow. Thanks in advance!
Posted Sat 21 Oct 17 @ 1:04 pm
The plugin you need is called TimeSkip however you need to be a licensed user to download it.
Posted Sat 21 Oct 17 @ 1:45 pm
That's exactly what I needed. Is there no way I can get that for free? I really would be needing that for one day only!
Posted Sat 21 Oct 17 @ 3:03 pm
Sorry it's not possible to do that, however you coold get a Pro subscription for a month and then you can download it.
Posted Sat 21 Oct 17 @ 4:14 pm
