Topic: Jumping BPM / Wrong speed detection
Hello dear VDJ community.
I have the following setup ...
2x Stanton S.150
2x VirtualDJ8 Timecode Vinyl from the VDJ-Shop
1x Allen & Heath Xone 22
1x Hercules DJ Trim
and of course VDJ8
everything runs on a MacBook Pro (late 2013) with macOS Sierra
and the following problem ...
VDJ8 has been reinstalled. Timecodes calibrated and everything works.
If I now add a song in DECK A , then the pitch display jumps to 0.3% or a similarly small value from the beginning.
If I match the track in the DECK B, then the BPM jumps and the track runs faster forward extremely audibly.
I haven't this problem with VDJ7 and the old Numark Timecodes. In VDJ 7 the mixes are very precise. But I would like to use version 8.
BPM autoMatch is set to NO.
Is there the possibility to adjust the sensitivity of the speed recognition?
I am already afraid of the next gig, because my crossing may currently only take a maximum of 10 seconds.
Maybe someone has an idea.
best regards
Andre
Posted Thu 19 Oct 17 @ 8:03 am
I have this same issue with 3967 & XDJRX with latest full midi firmware
I get a quick Downloading messege on the GUI & the XDJ decks start flashing and either one of the tracks will jump up .5 - 2 bpm.
Ever since full midi mode has been implimented it seems.
I also noticed the Controllers mapping window jumps through 5 or 6 different mapping commands during the “downloading flashing sequence/issue”.
[ONINIT:PITCH:SPEED_ADJ:INPUT_HW:DECK:GAIN:EQ_HIGH/MID/LOW]
I tried to figure out and disable them few commends but it hasnt worked.
Disabling auto bpm, key, smart etc has not help.... only thing that stops this issue is disabling/deleting the pitch/tempo slider all together. But im not 100 on that either.
It must be somthing to do with full midi support and the hw/sw pitch tempo slider differences or a change on the fader to master...?
Any help please, i will so appreciate it.
Surface I5, 8GB ram. Windows 8.1
Vdj 3967. Silver sleek skin
Xdjrx 2.21 firmware
Posted Wed 22 Nov 17 @ 5:11 am
