Can anyone tell me what I'm doing wrong here, please.
Cant seem to get this working
Posted Sat 14 Jan 17 @ 11:48 pm
I just tried it and I couldn't get it to handle colons. Also, you need to use
filepath contains "my music"rather than using
=otherwise you will need to specify the exact file name.
Posted Sun 15 Jan 17 @ 12:34 am
Thanks a whole lot
i've been trying everything else, didn't think that would be the one
Now my filters can be "folder specific"
Posted Sun 15 Jan 17 @ 1:58 am
To see which text the filter folder is using exactly, it can also be a good idea to show this column in the browser.
Then you would have seen that the file path column indeed doesn't include the drive letter.
Posted Sun 15 Jan 17 @ 10:50 am
Sorry for reviving the post, but how can i get that to work with 2 folders at the same time? Im trying to make a filter including only two folders called "Músicas Zouk Nuvem" and "Kizomba" using the following code but it isn't working:
bpmdiff<=4 and keydiff=0 and Filepath contains "Músicas Zouk Nuvem" and Filepath contains "Kizomba"
The following code works but only for 1 folder: bpmdiff<=4 and keydiff=0 and Filepath contains "Músicas Zouk Nuvem"
Can anyone give me a hand?
Posted Mon 15 Apr 19 @ 5:59 pm
change the last "And" to "or"
Posted Mon 15 Apr 19 @ 6:08 pm
Didn't work out :(... For some reason he gives me a syntax error
Posted Mon 15 Apr 19 @ 6:23 pm
bpmdiff<=4 and keydiff=0 and Filepath contains "Músicas Zouk Nuvem" or Filepath contains "Kizomba"
Posted Mon 15 Apr 19 @ 6:29 pm
That worked out! I only had to isolate each sentence with ( ) in order to have the bpm and key diff's be considered for each folder. Thank you!
Posted Mon 15 Apr 19 @ 6:48 pm
