Forum: VirtualDJ Skins
Topic: VDJscript syntax for setting autoCue "no" and "skip silence"
I need to change this setting according to certain sessions I do.
What would the correct syntax be to set autoCue to "no" and to "skip silence"?
Posted Thu 08 Dec 16 @ 11:12 am
setting "setting name" "setting string"
here's a real example
setting "autocue" "cue/skip silence"
Posted Thu 08 Dec 16 @ 12:35 pm
Wow. That simple, huh?
So...
setting "autocue" "skip silence"
...and...
setting "autocue" "no"
...would do the trick? Almost can't believe it's that simple ;)
Posted Thu 08 Dec 16 @ 12:37 pm
I only tested my example but, yep that should do it.
Posted Thu 08 Dec 16 @ 1:19 pm
Can't try it out now, but will do it later. As always, many thanks locodog!
Posted Thu 08 Dec 16 @ 1:30 pm
Works great!
THANK YOU locodog :)
Posted Sat 10 Dec 16 @ 9:54 am
