Further discussion for this blog tutorial
http://www.virtualdj.com/user/locodog/blogs/5460/How_to__Remap_HW_FX_Dial_1_To_Another_FX_Dial_For_A_Specific_FX.html
This one isn't easy but it takes customising to the next level
Posted Tue 04 Oct 16 @ 1:40 am
Alright then, a bit of cross posting but I'll do it here as here's where it should be.
SoundInsurgent uses the Denon MC4000 and wants to control dial 2 of the audio cut8 effect whilst in multi fx mode without pressing shift
These are the default mappings
FX1 effect_slider 1
FX 2 effect_3slots_layout ? effect_slider 2 1 : effect_slider 2
FX 3 effect_3slots_layout ? effect_slider 3 1 : effect_slider 3
These are the new mappings
FX1 param_equal '`get_effect_name 1`' 'Audio Cut8' ? effect_slider 1 2 : effect_slider 1 1
FX 2 effect_3slots_layout ? param_equal '`get_effect_name 1`' 'Audio Cut8' ? effect_slider 2 2 : effect_slider 2 1 : effect_slider 2
FX 3 effect_3slots_layout ? param_equal '`get_effect_name 1`' 'Audio Cut8' ? effect_slider 3 2 : effect_slider 3 1 : effect_slider 3
FX1 effect_slider 1
Posted Thu 06 Oct 16 @ 4:02 am
Thanks bro, ill be trying this out on both my 4000 and DDJ SP1.
Posted Thu 06 Oct 16 @ 4:08 pm
